Maytag Front Load MAH2400AWW with '3E' error code.
6 replies to this topic
#1 AlexM
AlexM
    Sōhei
  • Chief Appliantologist
  • 240 posts
  • Flavorite Brew:Root Beer
Posted 08 December 2012 - 08:45 PM
Maytag Front Load Washer Model# MAH22400AWW could use a service manual if available.  All i know is that there is a '3E' error code, not sure what that is?  Thanks,
#2 john63
john63
  • 1,411 posts
Posted 08 December 2012 - 08:57 PM
<<<'3E' error code, not sure what that is>>>
In most cases---a failed MAIN BOARD.
Samsung-built unit.
Doesn't hurt to verify that the HALL SENSOR and MOTOR are okay---before ordering new MAIN BOARD
To eliminate:
Musty odor
L-O-N-G cycle times
Dingy/yellowing whites
Suds error message
Slow spin speeds
Read below:
HE 2X: (1) Tablespoon
HE 3X: (1) Teaspoon
#3 RegUS_PatOff
  • 30,216 posts
Posted 08 December 2012 - 09:30 PM
http://appliantology...compact-washer/
#4 AlexM
AlexM
    Sōhei
  • 240 posts
Posted 18 December 2012 - 10:32 PM
Well,  I guess i'm not paying attention to your advice.  I ordered a new board without checking the motor or hall sensor ( I have no idea what a hall sensor is? any explination would be appriciated), i put the new contol board in and it will fill, drain but will not spin or the drum will not turn at all.  I can turn it manually, belt is hooked up.  So in stead of looking at this post i ordered a new motor and door latch thinking it had to be one of the two, never thinking to investigate a hall sensor.  How would i test the motor and hall sensor?  Thanks.
#5 kdog
    RoughShod
  • 7,428 posts
Posted 19 December 2012 - 02:09 AM
Tach is internal to motor on this one - see page 11/12 of the second download (tech sheet)
#6 AlexM
AlexM
    Sōhei
  • 240 posts
Posted 19 December 2012 - 11:43 PM
Got the new motor installed today, and all good to go. thanks for all your help.
Edited by Samurai Appliance Repair Man, 20 December 2012 - 05:11 AM.
Added part link to motor.
  • 24,247 posts
Posted 20 December 2012 - 05:13 AM
Thanks for the update, Alex.
Interestingly, the 3E failures in the 2400's apparently has the same cause and cure (replacing the motor) as in the 6700, 8700, and 9700 models:
http://fixitnow.com/...ah9700-washers/
