Should I repair, or buy new?
12 replies to this topic
#1 Bratton
Bratton
    Ikkō-ikki
  • Appliantologist
  • 52 posts
Posted 10 December 2012 - 07:35 PM
I have a frigidaire Model # FDB750RCS0. They heating element does not function and  the control dial sticks in 2 different places so it will run all day if I am not home.  I don't know the year of this unit ( at least 5 years old). Is this a cheap easy fix or should I just buy a new dishwasher?
#2 jumptrout
jumptrout
  • 1,142 posts
  • Flavorite Brew:Coors Light
Posted 10 December 2012 - 07:47 PM
The timer may be sticking because of the No Heat problem.
Where is it sticking and in which cycle?
#3 kdog
    RoughShod
  • 7,428 posts
Posted 10 December 2012 - 08:10 PM
http://www.repaircli...mber=FDB750RCS0
 (w/video):
High-Limit-Thermostat-154290204-00628954
#4 Bratton
Bratton
    Ikkō-ikki
  • Appliantologist
  • 52 posts
Posted 10 December 2012 - 08:30 PM
Sticks during the wash cycle, then again just before the drying cycle begins.
#5 kdog
    RoughShod
  • 7,428 posts
Posted 10 December 2012 - 08:33 PM
Test the fuse as in the video in the above link, order replacement there if the fuse is open
#6 Bratton
Bratton
    Ikkō-ikki
  • Appliantologist
  • 52 posts
Posted 10 December 2012 - 08:49 PM
Where is that fuse? Easy access?
#7 kdog
    RoughShod
  • 7,428 posts
Posted 10 December 2012 - 08:54 PM
Yes - remove kickpanel, fuse is in series with heater along the left side underneath
#8 Scottthewolf
Scottthewolf
    Senpai
  • 1,919 posts
Posted 10 December 2012 - 09:36 PM
NEVER EVER run any of your appliances when you are not home.  The only appliance that should be on when you aren't home is your refrigerator.  You could come back to a flooded house or you might come home to find you  don't have a house  anymore cause it went up in flames.
Scott Wolf
#9 DurhamAppliance
    Sho' Nuff Chozin
  • 1,754 posts
Posted 10 December 2012 - 11:49 PM
"Should I repair my old appliance or buy a new one?"   An age old question. However, with many of these new appliances, the current question is "should I repair my old appliance or buy a new one and repair it?"
Edited by DurhamAppliance, 10 December 2012 - 11:54 PM.
#10 Chat_in_FL
Chat_in_FL
    Senpai
  • PipPipPipPip
  • 897 posts
  • Flavorite Brew:Variety is the spice of life!
Posted 11 December 2012 - 06:28 AM
Does the heating element get hot if you advance the timer to dry (yeah -- I know you said heating element does not function, just double checking :thumbsup: )? This thing has "booster" thermostats that stall the timer until they sense the water is hot. If the heater and "Hi-Limit" thermostat check OK, then I would suspect these "booster" thermostats (not pictured of parts diagram).
Edited by Chat_in_RI, 11 December 2012 - 06:59 AM.
Mother Teresa
#11 Budget Appliance Repair
  • 4,001 posts
Posted 11 December 2012 - 08:09 AM
Most likely going to be the hi-limit safety t-stat in the left rear corner as Kdog linked to.  Seems to be a somewhat common problem on these Frikadaire dishwashers.
All the ones I've seen fail has been because of the rivet that holds the terminal to the t-stat itself being loose and causing the connectors to over heat thus causing the t-stat to fail.   Be sure to replace the wiring and connector also if they look at all burnt/overheated.
William Burk (Willie)
Eureka, CA 95501
#12 Bratton
Bratton
    Ikkō-ikki
  • Appliantologist
  • 52 posts
Posted 11 December 2012 - 08:31 PM
In reply to Chat in RI ( guessing that is the "Ocean State" ) the heating element does not warm up when advancing to the drying cycle. I will check the heating element and the hi limit T stat and go from there.
Hoping K dog is correct.
#13 kdog
    RoughShod
  • 7,428 posts
Posted 11 December 2012 - 08:49 PM
As Willie mentioned, it is quite common
