Jenn Air Expressions Cook Top: Knobs for burners won't turn
jenn air expressions cooktop
5 replies to this topic
#1 MSimpsonNJ
MSimpsonNJ
  • 15 posts
  • Flavorite Brew:Stella Artois
Posted 11 December 2012 - 10:12 AM
My sister in law has a Jenn Air Expressions cooktop, Model # CVGX2423Q.  She just called and told me that none of the burner knobs will turn.  I suspect that there must be some probelem with the ignition system and that there is a safety feature that prevents the gas from flowing (i.e., blocks the knobs from turning) when the igniters are non-functional.  She says the cooktop has power.  Any ideas?
Thanks.
Mark
#2 RegUS_PatOff
  • 30,300 posts
Posted 11 December 2012 - 11:56 AM
Has this Cooktop worked OK at this location until now ?
CVGX2423Q  c.1997
from the user manual:
Push down the control knob and tum immediately counterclockwise to the desired setting.
#3 MSimpsonNJ
MSimpsonNJ
  • 15 posts
Posted 11 December 2012 - 01:39 PM
CVGX2423Q  c.1997
Yep - it has been working fine for years until now, though she said that she thought last week it seemed a little harder to turn the knobs.  Not sure if that is real or imagined.  Seems odd that suddently none of them can be turned....
  • 24,360 posts
Posted 11 December 2012 - 04:07 PM
This has to be a user error because the chances of all surface burner valves going bad at the exact same time are somewhere between zero and nada.
How old is your sister-in-law?  I have lots of elderly customers who one day suddenly forget how to use an appliance they've used for years.   I can personally attest that this same phenomenon afflicts middle-aged folks, too.
As Brother Reginald has pointed out:
...from the user manual:
#5 MSimpsonNJ
MSimpsonNJ
  • 15 posts
Posted 11 December 2012 - 04:33 PM
Hmmm - very strange.  She is only 50 and doesn't usually begin drinking until after 5:00  ;)
I'll have to call her and interrogate her some more.  She's sharp and i doubt it is her - she has been using this cooktop everyday for a long time.  I completley agree that all of them going at one time would be virtually impossible - hence my suggestion that it might be a protective measure.  Since that isn't it, I may have to suggest she call a repairperson (horrors).
Thanks.
#6 kdog
    RoughShod
  • 7,428 posts
Posted 11 December 2012 - 08:28 PM
Something got spilled, or boiled over ..............
