Sears 110.92585800
clutch spin slow
5 replies to this topic
#1 tmfixit2
tmfixit2
  • Chief Appliantologist
  • 7 posts
  • Flavorite Brew:The local stuff
Posted 12 December 2012 - 02:08 PM
Hello, again.
Today my washing machine is starting to act up.  It appears that it spins too slow.  If I move it back and forth by hand it feels tight but after a couple of back and forth turns, it frees up a bit, but not for long.  I had reports of a burning type smell, but I did not smell this myself.
My conclusion is that the clutch is shot and binding.  What I'm looking for is a confirmation that this is the likely culprit for this type of problem.
Thanks in advance.
tm
#2 kdog
    RoughShod
  • 7,428 posts
Posted 12 December 2012 - 09:46 PM
Sock/Panties between tubs.
http://appliantology...t-drive-washer/
#3 tmfixit2
tmfixit2
  • 7 posts
Posted 13 December 2012 - 01:14 AM
This makes good sense and explains the free-sometimes, sometimes-not phenomenom.
I'll check this in the morning.
tm
#4 tmfixit2
tmfixit2
  • 7 posts
Posted 13 December 2012 - 08:28 PM
Nothing found in between the tubs but a heavy build up of lint type debris between the vertical center sections of both tubs.   Removal may or may not help, the spin clutch seems OK, I can see it working and there is still material on the clutch.
Since I didn't actually see this problem happen, burning smell and all, I'm thinking that the tub was overloaded and just took a long time to spin up to speed.
thanks,
tm
#5 Scottthewolf
Scottthewolf
    Senpai
  • 1,914 posts
Posted 13 December 2012 - 11:26 PM
Gearcase oil on the clutch will also cause a slow spin.  Look for a gearcase oil leak.
Scott Wolf
#6 tmfixit2
tmfixit2
  • 7 posts
Posted 14 December 2012 - 02:06 AM
Clutch is dry.
tm
