WT5001CW LG Top load washer rubbing, grinding noise during wash cycle
4 replies to this topic
#1 richseattle56
richseattle56
    Kohai
  • Chief Appliantologist
  • 295 posts
  • Flavorite Brew:Coors Light or Vodka
Posted 12 December 2012 - 06:43 PM
WT5001CW Top load washer. No noise in spin, no error codes, just rubbing noise in agitation, or maybe they call it nutate like the old Calypso.
  • 24,258 posts
Posted 13 December 2012 - 05:06 AM
This one is more like the Whirlpool Cabrio rather than the Calypso-- and thank the pit-bellied, buck-toothed, bald-headed Buddha for that!  Probably have a piece of clothing stuck between in the inner basket and outer tub.
Here's the service manual ==> http://appliantology...service-manual/
#3 nickfixit
nickfixit
  • 1,965 posts
Posted 15 December 2012 - 06:43 AM
remove the wash plate and check for a coin or other foriegn object. Under the center cap is a 10 mm screw, that all that holds the wash plate in.
#4 RegUS_PatOff
  • 30,226 posts
Posted 15 December 2012 - 08:54 AM
#5 nickfixit
nickfixit
  • 1,965 posts
Posted 15 December 2012 - 06:16 PM
We have seen the main control send power to more than one motor winding causing grinding noises that you would think was a gearcase issue.
