Frigidaire Electric Oven FGES3065KFA
12 replies to this topic
#1 GreenestOne
GreenestOne
    Yamabushi
  • Chief Appliantologist
  • 80 posts
  • Flavorite Brew:java
Posted 14 December 2012 - 09:32 AM
The owner complained that in the middle of the night the oven would start beeping and the error code  E0 -14 was displayed.
I looked online for for what the code was and how to take care of the problem. Two different sources said that I should open the console release the ribbons connecting the touchpad and the control board clean them with alcohol (even use a toothbrush), wait until the contacts were dry and reinstall them and check oven for operation. I did so and the error code E0-14 reappeared. Both sources said to replace the control board if this reoccured. I replaced the board and when turning the power back on the code PF for power failure appeared. I simply set the clock and all the functions of the stove were working.
The next day the owner called back and said the beeping happened again when they were NOT even using the oven.
They had turned the breaker off each time the code would come on. I went back out, turned the breaker on, reset the clock and everything
was working.
We had talked about past performance of the oven, the oven they had before, all on the same circuit. They had no problem with the older oven and none with the new one for about two years until the now(The present). The touchpad when keyed in performed
every function when I touched the pad. I thought at first perhaps with the oven heating up or the front burners near the touchpad on
the heat would somehow cause some expansion and cause a short in the electrical. BUT the problem appeared when the oven was not even on.
So?
#2 GreenestOne
GreenestOne
    Yamabushi
  • 80 posts
Posted 14 December 2012 - 09:36 AM
Sorry, I forgot to mention I had to go out again, the next day after the owner called telling me that the oven was beeping at 2:00a.m that morning. (3rd time)
#3 DurhamAppliance
    Sho' Nuff Chozin
  • 5,230 posts
Posted 14 December 2012 - 09:55 AM
Just stated this a few minutes ago in another post but may apply here as well....
I have been sent on many wild goose chases by board diagnostics and service manual recommended fixes suggesting board replacement only to find a bad thermal fuse or malfunctioning probe. So now I always check fuses, probe and door switches on all oven repairs before I replace a board. It can be a pain but can save time and the embarrasment of putting in a board only to find out it was a thermal limit fuse. No matter if you show the customer the service manual or error code advising board replacement, he will start to second guess your expertise as you give him the refund.
(ps... you can always tell the customer it needed a fuse as well as a board...but you may wind up in the seventh circle of appliantological hell so we won't ever do that now would we?  :devil:  )
Also with this error, don't rule out a malfunctioning keypad despite cleaning ribbons or testing buttons. btw did you clear error codes?
Edited by DurhamAppliance, 14 December 2012 - 10:05 AM.
www.DurhamApplianceThrift.com
#4 RegUS_PatOff
  • Academy Instructor
  • 33,588 posts
Posted 14 December 2012 - 11:08 AM
from the 318127057.pdf tech sheets:
E014
Loss of Display tail #0.
Check connection P1 on ESEC-UIB and P1 on ESEC Rotary HI Board (RR).
Loss of Display tail #1.
Check connection P2 on ESEC-UIB and P2 on ESEC Rotary HI Board (RF).
Loss of Keyboard Tail.
Check connection J2 on ESEC-UIB and J8 (RF).
#5 GreenestOne
GreenestOne
    Yamabushi
  • 80 posts
Posted 14 December 2012 - 03:01 PM
What is "loss of tail" ?
    Shōgun
  • Master Samurai Tech
  • 30,016 posts
Posted 15 December 2012 - 09:59 AM
That's when you ain't gettin' none o' dis:  essappqp.gif
#7 DurhamAppliance
    Sho' Nuff Chozin
  • 5,230 posts
Posted 15 December 2012 - 11:59 AM
That's when you ain't gettin' none o' dis:  [img]http://i160.photobucket.com/albums/t200/Zenzoidman/Shoebox/essappqp.gif[/img]
Lol... Now that's worth repeating.
#8 GreenestOne
GreenestOne
    Yamabushi
  • 80 posts
Posted 15 December 2012 - 12:40 PM
I was expecting something to help me complete this job. Did you guys understand what RegUS-Pat Off sent. I could read the schematic he posted, but don't
have enough related experience to know what I'm looking for. Even if I find different resistances, what needs to be replaced?
Need your help, thanks! I don't mind the joke.
#9 Chat_in_FL
Chat_in_FL
    Havoc
  • 1,452 posts
  • Flavorite Brew:What's on tap?
Posted 15 December 2012 - 02:14 PM
Loose or bad connection, check related connections.
Mother Teresa
The views and opinions expressed in this post are those of the author and do not necessarily reflect or represent the views and opinions held by my employer. All data and information provided is for informational purposes only.
Big Brother
#10 DurhamAppliance
    Sho' Nuff Chozin
  • 5,230 posts
Posted 15 December 2012 - 04:43 PM
You're right. We just thought you understood what to do but just wanted to know a term of art. Heck, I hardly ever know what  Sensei Reg is talkiing about, I just do what he suggests. Anyhow Samurai, you and I have been caught passing notes and acting up in class. I guess we gotta go sit in  the Academy's time-out room for a while.
#11 kdog
    RoughShod
  • 7,466 posts
Posted 16 December 2012 - 03:00 AM
Those ranges are nasty!  the codes you are seeing are related to the surface unit components which are potentiometer controls that also feed into the main board so any of those ribbons can cause issues. The diagnostic procedure only narrows it down to 2 of the 5 boards contained within the unit - so likely one or both of those or a potentiometer
#12 Samurai Appliance Repair Man
    Shōgun
  • 30,016 posts
Posted 16 December 2012 - 07:31 AM
#13 DurhamAppliance
    Sho' Nuff Chozin
  • 5,230 posts
Posted 16 December 2012 - 12:08 PM
i commend and admire your adherence to Bushido and I apologize, Sensei, for my lack of faith in the philosophical principles of the warrior code. Although less dramatic, I'd rather adhere to the cowardly, procrastinatory priniciples of certain western religions .... ie... I'd rather burn in hell TOMORROW, for any sins I commit today. So back to the boring yet painless time-out room for me.
