Kenmore Refer Mod#106.58582892 warm in top of freezer
7 replies to this topic
#1 deezus
deezus
    Kohai
  • Chief Appliantologist
  • 297 posts
Posted 14 December 2012 - 01:36 PM
This unit was getting warm in top of freezer area and the cold control had to be turned up in order for it to cool. Tested cold control it passed. I notice a thin line of frost forming on center of freezer wall on evaporator cover. This didn't happen all the time. So, we replaced the adaptive defrost timer. work3d for a week now its doing the same thing. So either a bad timer again or a faulty cold control ? Even though CC tested fine? Any help would be appreciated. Also, ohmed out compressor and it tested fine. Thanks.
#2 RegUS_PatOff
  • 30,203 posts
Posted 14 December 2012 - 01:43 PM
... thin line of frost forming on center of freezer wall on evaporator cover.
OR bad Defrost Heater or Defrost Terminator Thermostat ..
OR possibly leaky Sealed system
Evaporator frost pattern pictures may help
#3 deezus
deezus
    Kohai
  • 297 posts
Posted 16 December 2012 - 10:52 PM
Evaporator has even frost pattern, Bimetal and board have been replaced, What happens is the evap fan stops running and the freezer starts getting warm. Then if you turn the CC up it comes on again. But if I test the CC it tests fine......im just wondering if a CC can have intermittent failings? Like worok sometimes and other times not and the same when you test it? As I understand it the evap fan on this model should constantly be running right?
#4 RegUS_PatOff
  • 30,203 posts
Posted 16 December 2012 - 11:50 PM
... As I understand it the evap fan on this model should constantly be running right?
1) yes
2) both Fans should be running whenever the Compressor is running
http://www.repaircli...sp?R=154&N=2299
#5 deezus
deezus
    Kohai
  • 297 posts
Posted 16 December 2012 - 11:55 PM
Ahh, so the cold control being bad turns off the compressor and the fans?
#6 RegUS_PatOff
  • 30,203 posts
Posted 17 December 2012 - 02:31 AM
yes
Wiring Sheet - 2200277.pdf
#7 Budget Appliance Repair
  • 3,998 posts
Posted 17 December 2012 - 07:11 AM
That is actually one of the more common failure modes of a cold control to be intermittent.
If you pull the old one apart after you replace it, I can pretty much guarantee that you will find the contact points look quite crispy and melted.
One good way to know this is your problem is when you find that the unit it off and starting to thaw out, don't turn or touch the control dial, just give the control area a good slap and if it starts when you do that you can be pretty much assured you have a bad cold control, (the jolt or turning it up or off/on will make the contacts connect again until it opens and tries to close on its own).
Edited by Budget Appliance Repair, 17 December 2012 - 07:12 AM.
William Burk (Willie)
Eureka, CA 95501
#8 Scottthewolf
Scottthewolf
    Senpai
  • 1,911 posts
Posted 18 December 2012 - 09:20 PM
You might also find black dust around the cold control if it's going bad.
Scott Wolf
Tip for checking a mechanical cold control in a refrigerator
By Samurai Appliance Repair Man in Samurai Appliance Repair Man's Blog, on 17 December 2012 - 09:15 AM
Some refrigerators use a mechanical cold control like this one:http://www.rcappliancepartsimages.com/dbImages/i/00002100/Temperature-Control-Thermostat-2198202-00632606.jpg  for regulating the temperature inside the compartments. These controls have a feeler capillary tube attached to the body of the cold control. Inside the body, changes in temperature,...
Read Full Entry →
