kenmore dryer 110.60622990
Dryer shuts off
5 replies to this topic
#1 tpoindexter
tpoindexter
    Sōhei
  • 245 posts
  • Flavorite Brew:Beamish
Posted 18 December 2012 - 12:54 PM
Original complaint: Dryer keeps shutting off
checked dryer and vent for airflow=good
Customer said it only happens on the timed cycle and in the same place on the timer each time.
set dryer to 10 min. before that spot and went and did paperwork for about 20 minutes. came back dryer was past the spot on timer and still going.
took dryer apart and cleaned, checked for loose wiring.
suspected motor was overheating and shutting off, so replaced motor.
Customer calls me 2 weeks later and says now it's shutting off on auto cycle, and permanent press, but working fine on timed dry.
Now I don't feel like a ballerina anymore... any help on what I'm missing?
Test
#2 jumptrout
jumptrout
  • 1,192 posts
  • Flavorite Brew:Coors Light
Posted 18 December 2012 - 01:12 PM
Perhaps the load is hitting the door and causing intermittent contact of the door switch.
Temmis shoes are famous for this problem.
#3 tpoindexter
tpoindexter
    Sōhei
  • 245 posts
Posted 18 December 2012 - 01:25 PM
thanks, I'll check the door and ask some questns when I go  the tomorrow
Test
#4 Scottthewolf
Scottthewolf
    Senpai
  • 1,933 posts
Posted 18 December 2012 - 08:53 PM
Please move this to the laundry forum.
Scott Wolf
  • 24,720 posts
Posted 18 December 2012 - 08:56 PM
Topic moved.  Domo, Scott!
#6 kdog
    RoughShod
  • 7,433 posts
Posted 19 December 2012 - 01:47 AM
Also check centrehub of timer knob see if it's broken or stripped.
Almost cheaper to do the motor though    :woot:
http://www.repaircli...er=110.60622990
