Dishwasher lower spray arm melted
4 replies to this topic
#1 lifierro
lifierro
  • Chief Appliantologist
  • 18 posts
  • Flavorite Brew:Dos Equis
Posted 18 December 2012 - 05:10 PM
Frigidare Dishwasher Model # FBD2400KB3A
 I have had two service calls for the same Dishwasher and Model where the lower spray arm was melted by the heater element.  Does anyone know why this is happening?
#2 Scottthewolf
Scottthewolf
    Senpai
  • 1,911 posts
Posted 18 December 2012 - 08:51 PM
Were the 2 aluminum heat shields (one on each side on the bottom of the spray arm) still on the spray arm or were they missing?
Scott Wolf
#3 certified tech group 51
  • 1,974 posts
Posted 18 December 2012 - 10:49 PM
P/N 154335201  spray arm nut may be worn down to the point it will no longer hold the spray arm clips tight enough..................................... opps.. reread the post , thought the spray arm was fall off and melting on the element.......
#4 lifierro
lifierro
  • 18 posts
Posted 19 December 2012 - 07:27 AM
Yes the heat shields are still on the spray arm. Its weird because the burn marks are not on the spray arm that moves over the heater element but about a inch or two closer to the center.
#5 jumptrout
jumptrout
  • 1,132 posts
  • Flavorite Brew:Coors Light
Posted 19 December 2012 - 07:30 AM
This hi limit stat may be bad and causing overheat. http://www.repaircli...ber=FBD2400KB3A
