LG (and Kenmore) Recalls TOP Load Washers Due to Injury Hazard
9 replies to this topic
#1 RegUS_PatOff
  • 30,216 posts
Posted 18 December 2012 - 07:50 PM
Hazard: An unbalanced load can cause the washing machine to shake excessively and the drum to come loose during use,
posing a risk of injury to consumers and property damage to the surrounding area.
Remedy: Consumers should immediately contact LG or Sears for a free in-home repair of the machine.
Consumers will also receive supplemental information to be inserted into their owner's manual and a new caution label to be placed on the washing machine.
Consumers who have observed their recalled washing machine shaking excessively should immediately stop using it.
Consumers should be aware that loading their machines with water-proof or water-resistant items,
such as mattress pads, mattress covers and similar items, increases the chances of loads being unbalanced.
http://www.cpsc.gov/...ml13/13073.html
Brand Model Serial Number Range
LG
WT5001CW 002KW*******
WT5101HV through WT5101HW 111KW*******
Kenmore Elite 29002 005KW*******
29272 through 29278 111KW*******
#2 Alcamo
Alcamo
  • 16 posts
  • Flavorite Brew:Harpoon UFO
Posted 18 December 2012 - 08:24 PM
Any idea what the repair entails and what part(s) are modified or replaced?
#3 RegUS_PatOff
  • 30,216 posts
Posted 18 December 2012 - 08:27 PM
in the past, it was just a software modification to the Controller ....
for balancing / slower Spin speeds
#4 appl.tech.29501
appl.tech.29501
  • 8,019 posts
Posted 05 January 2013 - 01:31 PM
Yep authorized techs are sent ( jigs) they like to call them for changing the soft ware...haven't gotten mine yet though....
www.eliteapplianceservice.org
#5 RegUS_PatOff
  • 30,216 posts
Posted 05 January 2013 - 02:12 PM
it's been awhile :beach:
#6 appl.tech.29501
appl.tech.29501
  • 8,019 posts
Posted 06 January 2013 - 08:36 AM
Yes it has, I've missed you guys. ..hoping for a better 2013 !
#7 nickfixit
nickfixit
  • 1,964 posts
Posted 01 February 2013 - 06:07 PM
I did my first software update, it was pretty easy. I had to stoop to the level of actually reading the directions that came with the tool. Easy work, all you need is the tool set and a phillips screwdriver.
And, the pictures in the directions suck, almost as bad as frigidaire does on their little projects.
#8 sh2sh2
sh2sh2
    Sōhei
  • 211 posts
  • Flavorite Brew:yeunling
Posted 01 February 2013 - 08:45 PM
i have done about 20 of them now.  The first one i did my tool was messed up.  It deleted the programing but then would not upload the new flash.  Got another tool and no problems since.
#9 john63
john63
  • 1,411 posts
Posted 01 February 2013 - 09:57 PM
Service Tip...
If after the software update is performed---and the washer is found to be "dead" (no lights at all)...
Repeat the reflash procedure.
I did one and had an incident in which it appeared that coincidently---the MAIN BOARD had also failed during a software update procedure.
In this instance---I had unplugged the "jig" immediately after it displayed "100 percent" downloaded.
During the 2nd reflash I waited a few seconds longer---and the software version was displayed.
Failing to wait an extra 2 to 3 seconds will result in a seemingly inexplicable "dead" MAIN BOARD symptom :)
To eliminate:
Musty odor
L-O-N-G cycle times
Dingy/yellowing whites
Suds error message
Slow spin speeds
Read below:
HE 2X: (1) Tablespoon
HE 3X: (1) Teaspoon
#10 sh2sh2
sh2sh2
    Sōhei
  • 211 posts
Posted 02 February 2013 - 07:16 PM
the one i had kept giving me a message that read "file fail" right after it did the deleting step but before it started counting the %, and on the toploads were updating the display boards
Edited by sh2sh2, 02 February 2013 - 07:18 PM.
