Kenmore washer 110 47532601 water in fabric softener dispenser at end of cycle
Kenmore washer
11 replies to this topic
#1 TonyLima
TonyLima
  • Chief Appliantologist
  • 8 posts
Posted 19 December 2012 - 05:57 PM
In the last few weeks I've noticed a lot of water in the fabric softener dispenser at the end of a wash cycle.  I mean a lot -- above the "max fill" line.  This washer model is front-loading and has a single drawer for detergent, bleach, and softener.  Only the softener slot contains water.  I have no idea what's causing this or, for that matter, even whether it's a problem.  Thanks for any advice/help.
Tony Lima
:wacko:
#2 jumptrout
jumptrout
  • 1,142 posts
  • Flavorite Brew:Coors Light
Posted 19 December 2012 - 06:26 PM
Seems your tubing is restricted. Run a small flexible wire down the FS hole to clear the blockage.
#3 TonyLima
TonyLima
  • 8 posts
Posted 19 December 2012 - 06:56 PM
Thanks.  Already ran brushes through various slots and crevices in the drawer.  Let me see what I can do about the tubing behind that.  Stay tuned.
#4 sh2sh2
sh2sh2
    Sōhei
  • 213 posts
  • Flavorite Brew:yeunling
Posted 19 December 2012 - 07:33 PM
also make sure your getting good water flow, if the inlet valve screens are clogged it can cause dispensing issues
#5 nickfixit
nickfixit
  • 1,965 posts
Posted 19 December 2012 - 07:53 PM
Pull out the drawer and peek into the inner housing.Is there a bunch of yucky looking grunge inside? If so, get yourself a toilet brush, some hot water and your favorite spray cleaner(helps if it has bleach) and scrub that puppy out.
#6 Scottthewolf
Scottthewolf
    Senpai
  • 1,919 posts
Posted 20 December 2012 - 12:00 AM
Liquid fabric softner is nasty stuff.  It's mostly wax and it clogs dispensers and causes mold issues. I prefer the fabric sofner sheets for the dryer, but there is also a debate over those that they clog the lint screens.
Scott Wolf
#7 nickfixit
nickfixit
  • 1,965 posts
Posted 20 December 2012 - 07:09 AM
Ever try this one...
Set the unit to a hot wash cycle, then manually hold the dispenser in the softener position. A combination of scrubbing from the outside, and hot flush from the inside can clean it out real nice. You can drain the machine and do it several times. Even run water at a sink to get the water good and hot first.
#8 TonyLima
TonyLima
  • 8 posts
Posted 21 December 2012 - 02:04 PM
Thanks for all the great suggestions.  The problem is now fixed!  I couldn't have done it without you!
Tony Lima
:wink:
#9 jumptrout
jumptrout
  • 1,142 posts
Posted 21 December 2012 - 02:06 PM
Tony Lima
:wink:
Please tell us what the solution was.
  • 24,345 posts
Posted 21 December 2012 - 04:30 PM
#11 kdog
    RoughShod
  • 7,428 posts
Posted 21 December 2012 - 06:14 PM
#12 TonyLima
TonyLima
  • 8 posts
Posted 21 December 2012 - 07:09 PM
Sorry.  I use so many different online forums it's difficult to keep track of the various options.  I used a set of small brushes to ream the various holes and slots in the drawer,  I used a bigger brush to clean out the port that holds the drawer.  One little gotcha: there's a hole near the front of the port just behind a block of plastic.  Run a brush down there, too.
