Complaint came in that the washer works great in all ways except that the hot water doesn't fill. I order a new valve without every seeing with my own eyes. I installed the valve and still not hot water. If you start the load on Cold/Cold it will start to fill then if you switch to Cold/Hot all water stops filling then a humming noise at the valve. I figure it needs a new main control board part# WW12X10323 ?
GE Top Load Washer WHRE5260E1WW , Hot Side Water Valve
#1
Posted 20 December 2012 - 12:02 AM
#2
Posted 20 December 2012 - 12:07 AM
I typed in the wrong part number for the main board, what i meant was WH12X10323
#3
Posted 20 December 2012 - 12:15 AM
Didja type in the wrong model number too ? that one doesn't come up.
Is there any Hot Water pressure available to the machine ?
#4
Posted 20 December 2012 - 12:21 AM
My bad, Model# WHRE5260E1WW. Good question about the hot wat supply. I turned both hot and cold valves off at wall to change the valve, but did't pay attention to actual flow from the hot.
#5
Posted 20 December 2012 - 12:25 AM
Corrected topic title - hook wire from cold valve to hot solenoid and see if it fills, if not - correct plumbing as necessary
- Samurai Appliance Repair Man and tommytech like this
#7
Posted 21 December 2012 - 06:19 AM
Beware of the "flood-safe" hoses, we see lots of them that don't allow any water into the washer.
- Samurai Appliance Repair Man, kdog, RegUS_PatOff and 3 others like this
#8
Posted 22 December 2012 - 12:17 AM
Funny you should mention the 'flood-safe' hoses. I swapped out the hot one with a regular stainless hose and now all is good, except two trips and a new valve that i didn't need to purchase. Man, learning hurts sometimes.
- Samurai Appliance Repair Man, nickfixit, kdog and 2 others like this
Advice on Using Flood-Safe Hoses with a Washing Machine
By Samurai Appliance Repair Man in Samurai Appliance Repair Man's Blog, on 23 December 2012 - 07:10 AMRead Full Entry →
