Imbera VR-06
6 replies to this topic
#1 Patricio
Patricio
    Kohai
  • Chief Appliantologist
  • 451 posts
  • Flavorite Brew:Most anything wet excluding DR. Pepper
Posted 20 December 2012 - 10:02 PM
Small Coke refer does not cool.  Compressor will kick on then click & go off.  fans run continuously.  Has a very small PTC relay & compacitor.  A thermo protector is wired to the common terminal.    I have 131 volts at the start terminal & 120V @ run terminal.   I think that the start relay does not kick out & thus the thermo protector kicks out.  After a few minutes compressor starts up again only to kick out. Am I correct in thinking this.
Is there a some where I can obtain a new relay for this unit?
IgonFishn & Tight Lines
#2 RegUS_PatOff
  • 30,281 posts
Posted 20 December 2012 - 11:02 PM
Danfoss 117U6102 PTC Starter Relay
http://www.gsistore.com/da11re1.html
parts manual
http://appliantology...ca-cola-cooler/
#3 Patricio
Patricio
    Kohai
  • 451 posts
Posted 21 December 2012 - 10:58 PM
Kool   You The DUDE Reg.    How you know that &/or find this stuff?    Also is it too much to ask can I have the overload also?   Thanks  Patricio.
#4 RegUS_PatOff
  • 30,281 posts
Posted 22 December 2012 - 08:01 AM
a lot of searching and cross-referencing
PTC starting device ( Texas Instr. ) with reduced loss of energy 117U6102
PTC (alt) starting device (Siemens) with reduced loss of energy 117U6106
Protector (Texas Instruments) 117U3304
here's a few more files added
http://appliantology...oss-compressor/
#5 Patricio
Patricio
    Kohai
  • 451 posts
Posted 22 December 2012 - 09:32 AM
Man or man    You da ONE.   uno numeral One.      Gracious,  Merry Christmas,  Felis Navidad.    Hi, Domo.
#6 Patricio
Patricio
    Kohai
  • 451 posts
Posted 06 January 2013 - 12:50 PM
Finally received the relay on the 4Th.  Them people are slow shippers.    Installed the relay.
Compressor runs continuously now, does not kick out.  Trouble is unit does not cool, therefore I have a sealed system failure.  According to wiring diagram both fans are in parallel & are running,  there is no defrost system to enter into the equation.   Have to condemn.   :wacko:  Bummer,  Friends wanted to use cooler in their office.
Edited by Patricio, 06 January 2013 - 12:51 PM.
#7 certified tech group 51
  • 1,988 posts
Posted 06 January 2013 - 09:19 PM
Fix-it..........Try and find the leak, If you are just going to sh%$t can it, there are a few ways to salvage a leaking unit..............I got about 18 months on a evac/rechared system and it is still going. ( leak some where )..................It is just a shop refer, not for sale..... You could use a system sealer,  ( Sorry Cactus Bob ).....to stop a small leak...................If it screws up the compressor, it don't matter cuz you were gonna chuck it any way..................
Edited by certified tech group 51, 06 January 2013 - 09:20 PM.
