whirlpool dryer ler7648pq1 dead
3 replies to this topic
#1 mrjtwright
mrjtwright
    Ikkō-ikki
  • 33 posts
  • Flavorite Brew:Samual Adams
Posted 22 December 2012 - 08:48 PM
i've had a mystery with this one.  it does nothing and the first time I took everything apart and checked what i thought was everything, put it back together and it worked.  now after several loads it's dead again.  The thermal fuse is ok, all thermal cutoffs test ok, there's 120v going to the start relay, the relay continuity tests out (even jumpered it) 0 ohms on the switch and about 1800 ohms on the coil,  door switch works.  Any ideas
#2 RegUS_PatOff
  • 30,300 posts
Posted 22 December 2012 - 10:26 PM
Does the Drum Light work ?
check for 120v at the Start Relay,
between the Blue wire and the Pink/Black wire, when the Start Button is pushed.
If no 120v, the check between:
the Blue wire and chassis (ground), when the Start Button is pushed.
#3 telefunkenu47
telefunkenu47
    Kohai
  • 322 posts
Posted 27 December 2012 - 01:18 PM
 Did you recheck the thermal fuse after it stopped working the first time? If not, check it again.
Edited by telefunkenu47, 27 December 2012 - 01:21 PM.
Even root canal is easy...if you're a dentist...
#4 mrjtwright
mrjtwright
    Ikkō-ikki
  • 33 posts
Posted 22 February 2013 - 01:52 PM
Yep, checked out fine.  No longer have access to troubleshoot this unit.  Thanks
