Frigidaire GAS dryer GLGR341AS4 heating intermittently
18 replies to this topic
#1 RedToryTy
RedToryTy
    Senpai
  • Chief Appliantologist
  • PipPipPipPip
  • 795 posts
  • Flavorite Brew:Guinness Stout
Posted 26 December 2012 - 04:30 PM
To the Dojo,
I went out on this dryer Saturday--"no heat." Get to the dryer and hear no double-clacking after the ignitor begins to glow; replace the valve coil solenoids, easy-peasy. After reassembling the dryer, I ran it for my normal three-cycle check routine...except the dryer wouldn't reignite any gas after its first heating cycle. Pulled the cover and watched it cycle flawlessly, and then ran the dryer disconnected from the exhaust pipe; no problems. Left that with the customer. Customer calls back today, complaining AGAIN of "no heat" Rechecked my airflow system, and that the vent isn't connected to the outside. I couldn't make it "no heat." This product has new solenoids and igniter. Am I missing something?
Thanks in advance,
Tyrus
Mr. Tyrus Lee Smith
Owner-Operator, Smith's Appliance Service
701 Baldwin Falls Road
Baldwin, Georgia 30511-2108
706-778-3411
#2 RegUS_PatOff
  • 30,241 posts
Posted 26 December 2012 - 05:52 PM
always works when the Vent is disconnected ?
#3 RedToryTy
RedToryTy
    Senpai
  • PipPipPipPip
  • 795 posts
Posted 26 December 2012 - 09:12 PM
As far as I've experienced; the customers says "sometimes will heat, sometimes not."
Mr. Tyrus Lee Smith
706-778-3411
#4 RegUS_PatOff
  • 30,241 posts
Posted 26 December 2012 - 09:20 PM
Dryer Vent
Vent should be rigid metal.
NO plastic
NO PVC
NO screws
Foil Duct Tape is OK.
Check / clean the Dryer Vent
#5 RedToryTy
RedToryTy
    Senpai
  • PipPipPipPip
  • 795 posts
Posted 27 December 2012 - 07:26 AM
Thanks for the reminders, Reg; I get all those correct indicators when I check the dryer DISCONNECTED. I guess I'm just frustrated with the call, having to bridge both technology and language gaps with this customer.
Mr. Tyrus Lee Smith
706-778-3411
#6 telefunkenu47
telefunkenu47
    Kohai
  • 322 posts
Posted 27 December 2012 - 09:42 AM
Ty: Does this dryer have a thermistor or a snap action tstat?
Even root canal is easy...if you're a dentist...
#7 RedToryTy
RedToryTy
    Senpai
  • PipPipPipPip
  • 795 posts
Posted 27 December 2012 - 04:17 PM
Snap-action thermostat (which has been replaced with new).
Mr. Tyrus Lee Smith
706-778-3411
#8 Wingerman
Wingerman
    Yamabushi
  • 77 posts
  • Flavorite Brew:Cuervo Silver and Lemonade
Posted 18 January 2013 - 11:34 PM
How responsive is the radiant sensor?
#9 RedToryTy
RedToryTy
    Senpai
  • PipPipPipPip
  • 795 posts
Posted 24 January 2013 - 06:41 AM
After using a vent-inside-the-house kit, the dryer works fine. My hypothesis is this hotel laundry room, high on a treeless hill, got enough gusting in the unhooded dryer vent to impact the drying of this dryer; venting it inside removed the outside wind variable = dry towels and bed linen.
Mr. Tyrus Lee Smith
706-778-3411
#10 RegUS_PatOff
  • 30,241 posts
Posted 24 January 2013 - 08:58 AM
local codes usually don't allow venting a gas dryer in enclosed living quarters ..
#11 Budget Appliance Repair
  • 3,999 posts
Posted 25 January 2013 - 07:26 AM
And more to the point, it's just not safe to do so!!!
William Burk (Willie)
Eureka, CA 95501
#12 RedToryTy
RedToryTy
    Senpai
  • PipPipPipPip
  • 795 posts
Posted 25 January 2013 - 08:52 AM
Please help, then. The venting to the outside is the problem; what would you guys do in this case?
Mr. Tyrus Lee Smith
706-778-3411
#13 RegUS_PatOff
  • 30,241 posts
Posted 25 January 2013 - 10:04 AM
clean the Vent
OR re-rout the Vent / shorter run
OR move the Dryer to an outside wall, shorter Vent run
#14 dimitri77565
dimitri77565
    Ikkō-ikki
  • 53 posts
  • Flavorite Brew:Railean Hand Made Rum
Posted 25 January 2013 - 10:09 AM
check timer for loose contact, disconnect & pull out & shake it. if you hear something loose inside bad timer.  It will work o.k. until it gets loose again.
You can also check wiring diagram & put a jumper on timer between L1 & heat wiring.  (this will give you heat all the time  NO COOL DOWN)
Strictly for test purposes.  Leave it & see if customer has problem.
CHARGE A LARGE FEE TO CUSTOMER, SO THEY WILL BE INCLINED TO CALL YOU BACK TO PERFORM CORRECT REPAIR.
Had a doctor customer that was too busy to call me back, went on for a year until coil kit went out.
#15 Samurai Appliance Repair Man
  • 24,279 posts
Posted 26 January 2013 - 09:20 AM
Many times, retrofitting a proper vent is a small construction project (sheet rock removal and replacement, etc.) and well outside the scope of most appliance techs who focus on troubleshooting and repair.  In these cases, I refer them to a small-jobs oriented builder here in town who has done excellent work for us.  In turn , he refers appliance repair jobs to me.  Your best bet is to establish a similar referral relationship in your area.
#16 Scottthewolf
Scottthewolf
    Senpai
  • 1,914 posts
Posted 27 January 2013 - 02:03 AM
This works for preventing backdrafts...
http://inspectapedia..._Lambro_023.jpg
Scott Wolf
#17 RegUS_PatOff
  • 30,241 posts
Posted 27 January 2013 - 05:46 AM
Lambro 289W
$ 16.99
eligible for FREE Super Saver Shipping on orders over $25
http://www.amazon.co...e/dp/B000BOB1FI
#18 SANTA
SANTA
    Senpai
  • PipPipPipPip
  • 691 posts
Posted 27 January 2013 - 01:24 PM
  If you scroll down on the Amazon page you will see the Heartland vent of the same style. They cost more but are better quality  http://www.amazon.co...g=mrssamskit-20
#19 Comstock_Services
Comstock_Services
  • 462 posts
Posted 29 January 2013 - 02:54 PM
I would recomend against leaving a jumper wire on a timer for anything so that the heat was on constant, Insurance is good but I don't wanna find out!
