Maytag Dishwasher MDB9150AWW
Drain Hangover
3 replies to this topic
#1 arrow 1
arrow 1
    Yamabushi
  • Chief Appliantologist
  • 64 posts
  • Flavorite Brew:Texas Tea
Posted 28 December 2012 - 05:56 AM
Unit cycles until drain cycle. It will try to drain in 2-3 second intermittent power surges. Checked sump all clear.
#2 jumptrout
jumptrout
  • 1,124 posts
  • Flavorite Brew:Coors Light
Posted 28 December 2012 - 09:21 AM
Check the drain impeller.
http://www.repaircli...mber=MDB9150AWW
#3 arrow 1
arrow 1
    Yamabushi
  • 64 posts
Posted 28 December 2012 - 09:57 AM
Impeller is ok. I took apart down to sump . All is clear. It cycles through wash cycle but when gets to drain motor starts for 2-3 seconds then cuts out. in about 10 seconds it will start again and cut out in 2-3 seconds.
  • 24,204 posts
Posted 30 December 2012 - 02:26 AM
If the motor is cutting out while still getting voltage, then it's new pump-motor assembly time ==> http://www.repaircli...mber=MDB9150AWW
Pump-and-Motor-Assembly-6-915416-0061038
