pfs22sisbss condensor fan issues
12 replies to this topic
#1 fattony67
fattony67
  • 5 posts
Posted 29 December 2012 - 02:58 PM
I have a ge profile that was having problems keeping the tempurature down.  The condensor fan was running very slowly and the compressor would not start.  Through some reasearch on past posts I narrowed the compressor problem down to a bad starter relay.  I got good voltage readings at the j2 plug on the motherboard and assumed the condesor fan motor was bad as well.  I went to a local parts store which had the relay in stock and ordered the fan motor.  When I replaced the starter the condesor fired up and I used a small desk fan to cool the coils.  The unit is working like a charm now, except...
The new fan motor has been installed and it still runs very slowly.  I am getting 13.6v at j5 to j8 with the plug off and 13.6v at the fan motor connector with the fan attached and running.
Am I wrong in assuming the board is good?
How fast do these fans spin, it is spinning so slowly that I can count the rpm?
What are the odds the replacement unit is bad?
Any advise would be appreciated..
Tony
#2 RegUS_PatOff
  • 30,216 posts
Posted 29 December 2012 - 03:11 PM
Condenser Fan is single speed
J2-3 white common
J2-5 yellow 12v = Fan ON
J2-8 12v DC supply voltage
measure
J2-5 to J2-3 = 12v DC
J2-8 to J2-3 = 12v DC
#3 fattony67
fattony67
  • 5 posts
Posted 29 December 2012 - 06:27 PM
j2 5 to 3 = 3.5v
j2 8 to 3 . 13.5v
Bad motherboard?
I checked the recall notice but mine is 2 months too late.
Edited by fattony67, 29 December 2012 - 06:30 PM.
#4 vincef
vincef
  • Appliantologist
  • 17 posts
Posted 29 December 2012 - 06:50 PM
If there is a GE on the front of the refrig it's the motherboard.
I go through 7 to 10 a week.
VF
#5 RegUS_PatOff
  • 30,216 posts
Posted 29 December 2012 - 06:52 PM
Bad motherboard?
1) seems like it
2) first (2) characters of serial number ?
I'm not sure if it covers MotherBoards caused by a bad Condenser Fan
#6 DurhamAppliance
    Sho' Nuff Chozin
  • 1,737 posts
Posted 29 December 2012 - 06:54 PM
Good catch Sensei Reg! I thought he meant getting 13v at both pin 5 and pin 8. Not that he was measuring 5 to 8. I was trying to figure out what on earth could cause the problem. Kept coming up with "does not compute. " Anyhow yep, time for a new board.
#7 fattony67
fattony67
  • 5 posts
Posted 29 December 2012 - 06:55 PM
serial number VL
just a side note.  The unit is cooling very well while pulled away from the wall even with the slow moving fan.
#8 RegUS_PatOff
  • 30,216 posts
Posted 29 December 2012 - 07:01 PM
VL = Nov 06
bad MotherBoards in that model were
May 05 - Jul 06
Your model should have the "newer" MotherBoard, but seems to be bad
You may be able to see a burned resistor on the board ...
  • 24,243 posts
Posted 29 December 2012 - 07:03 PM
Unless you can positively prove that the condenser fan is good, replace BOTH the muthaboard and the condenser fan or you risk doing this again in just short time.
Muthaboard ==> http://www.repaircli...ber=PFS22SISBSS
Main-Control-Board-WR55X10942-01091474.j
Condenser Fan Motor ==> http://www.repaircli...ber=PFS22SISBSS
Condenser-Fan-Motor-WR84X10055-00654477.
#10 fattony67
fattony67
  • 5 posts
Posted 29 December 2012 - 07:11 PM
I just installed the new condesor fan this morning.  That's what had me confused.  I'll try a new mother board and follow up.
How can I confirm the replacement fan is good?
  • 24,243 posts
Posted 29 December 2012 - 07:16 PM
If the fan is getting a valid power supply and it ain't running, it's bad!
If the windings on the fan motor read open, it's bad!
If the fan won't run when you hot wire a 9v battery to it, it's bad!
#12 fattony67
fattony67
  • 5 posts
Posted 03 January 2013 - 04:53 PM
New motherboard installed and fan is working correctly.
Next I'll try to get the icemaker that has broken twice working.
Thanks for the support guys.
#13 kdog
    RoughShod
  • 7,428 posts
Posted 03 January 2013 - 08:55 PM
Ice-Maker-Assembly-WR30X10093-00698627.j
