Samsung DV330AGW will not power on
6 replies to this topic
#1 fugitive6
fugitive6
  • 4 posts
  • Flavorite Brew:Ginger ale
Posted 29 December 2012 - 05:19 PM
I have a Samsung front load dryer that has stopped powering on or powers on very intermittently and runs for a few seconds to a minute or so.  Dryer seems totally dead.  I'm thinking it's the power panel but would like some troubleshooting advice before I order one.  I'm a huge do-it yourselfer and would like to repair this dryer myself.
#2 kdog
    RoughShod
  • 7,433 posts
Posted 29 December 2012 - 08:53 PM
Start with the simple stuff - check electric plug in for proper 120v/240v, then remove dryer top and look for wire connection issues from the power.
#3 fugitive6
fugitive6
  • 4 posts
Posted 29 December 2012 - 09:59 PM
Those were the first things i've looked at.  I've connected it to two different outlets and the same result.  I've opened it up and looked at the connectors too.   Thnx for the help.
  • 24,698 posts
Posted 29 December 2012 - 10:16 PM
Service manual here ==> http://appliantology...t-track-manual/
#5 fugitive6
fugitive6
  • 4 posts
Posted 29 December 2012 - 11:40 PM
I just finished checking the wiring.  All the wiring looks good. Could i jumper out the power button by jumpering the com (white wire) to the on (blue wire) terminal or do i have to do something with the NO wire too?
#6 nickfixit
nickfixit
  • 1,988 posts
  • Flavorite Brew:Glen Livit
Posted 30 December 2012 - 10:53 AM
When you say "dead" do you mean no display and no function, or is it just failing to start the drum turning or keep running ? Have you tried it with the vent disconnected?
#7 fugitive6
fugitive6
  • 4 posts
Posted 30 December 2012 - 11:37 AM
Yes, it's totally dead.  No lights no functions.  I have it disconnected from the vent and the gas line atm.  Occasionally it will power on but it will only come on for a minute tops then shut off again.
