Jenn Air slide in downdraft JES9800BAS odd problem with Touchpad.
2 replies to this topic
#1 vincef
vincef
  • Appliantologist
  • 18 posts
Posted 29 December 2012 - 06:57 PM
Hi, I went out on a Jenn Air downdraft slide in range today and am a little perplexed.
Got there and touch pad is dead to the touch.. Flipped breaker, waited a few secs
flipped it back on then touch pad would accept functions and touching oven light went on immediately
as powewre went on. started programming control after 1 minute light in oven goes off and touch pad is unresponsive
but clock stays set. Burners work fine so it's all in the control or touch panel. I put a new board in
and have the same problem. Looking at schematic packed in range nothing is inline between pad and control
Instinct says change touchpad but it works fine for 60 seconds. Doen anyone know if there is a syncing
that has to happen like on GE Profile dishwashers? Any help is appreciated. Thanks
VinceF
#2 RegUS_PatOff
  • 30,698 posts
Posted 29 December 2012 - 07:12 PM
I wouldn't think a bad Touchpad could cause those symptoms ..
It looks like the Controller is directly powered at the P2-1 to P2-3
#3 vincef
vincef
  • Appliantologist
  • 18 posts
Posted 30 December 2012 - 02:43 PM
Looking at the wiring diagram, it doesnt seem like anything would kill power to
the touch pad. I'm going to need a service manual for this range, visually considerably different than the
JES9800AAS, which has a manual posted already. I'm going to put a manual request up
in that forum.
Vince
