Frigidaire DW FDB520RHS2 not finishing
5 replies to this topic
#1 RedToryTy
RedToryTy
    Senpai
  • Chief Appliantologist
  • PipPipPipPip
  • 798 posts
  • Flavorite Brew:Guinness Stout
Posted 30 December 2012 - 01:53 PM
To the Dojo,
My customer called back on this DW, saying it hadn't finished drying after about ninety minutes (NORMAL wash lasts 85). On my normal followup call, she said the dishwasher was working great; hence my confusion now. The suspects appear to be the thermistor, heating element, and control board. Does anyone know the ohm value of the Frigidaire thermistor? To check the heater, I would ohm and check amp draw during a cycle.
Thanks in advance,
Tyrus
Mr. Tyrus Lee Smith
Owner-Operator, Smith's Appliance Service
701 Baldwin Falls Road
Baldwin, Georgia 30511-2108
706-778-3411
#2 RegUS_PatOff
  • 30,281 posts
Posted 30 December 2012 - 02:40 PM
... hadn't finished drying after about ninety minutes (NORMAL wash lasts 85).
How long does it actually take, now ?
May be taking a longer time to initially heat the incoming water to required temperature ...
#3 RedToryTy
RedToryTy
    Senpai
  • PipPipPipPip
  • 798 posts
Posted 31 December 2012 - 07:01 AM
I raised the water heater thermostats to 125, Reg; someone else replaced both elements (and MAY have turned down the thermostats). I'm going back out today; I will talk with the customer before I go out and post the completion time.
Mr. Tyrus Lee Smith
706-778-3411
#4 RegUS_PatOff
  • 30,281 posts
Posted 31 December 2012 - 09:40 AM
normally set to 140F, unless there are children, or elderly adults in the house ..
http://www.ehow.com/...er-heaters.html
#5 RedToryTy
RedToryTy
    Senpai
  • PipPipPipPip
  • 798 posts
Posted 02 January 2013 - 06:47 AM
Roger that, Reg.
Went back out, discovering that after over two hours the dishwasher finally finished (with WH thermostats set to 130) but water on the door, in the tub, and on the dishes. Hi-limit safety thermostat on the tub ohmed continuity with no resistance, but the calrod heating element ohmed out at 15.25--6 ohms over what it should. Have ordered replacement and will install later this week. I would really like to put this dishwasher through a service cycle before leaving; the service manual offers no method for an FDB model without a Dialomatic control, though.
Thanks in advance,
Tyrus
Mr. Tyrus Lee Smith
706-778-3411
#6 RegUS_PatOff
  • 30,281 posts
Posted 02 January 2013 - 09:47 AM
FDB520RHS2 tech sheets mentions service cycle info
also mentions Heater = 900w
(=16 OHMs)
