Kenmore dryer 110.60612990 -- doesn't stop
27 replies to this topic
#1 DanInKansas
DanInKansas
    Sōhei
  • 157 posts
  • Flavorite Brew:Blue Moon or Lion Imperial or Shiner Bock
Posted 31 December 2012 - 11:16 AM
We got this unit into the store and the motor was a "hard start".  Shop owner gave me a motor, told me to replace it.
Replaced the motor and tested.  The unit reaches the end of the cycle, begins to buzz and does not stop buzzing.  Drum does not stop turning.
One of the delivery guys scrounged a timer out of a scrap unit and installed that, with the same results.
Seems like I must have made an error in motor installation, but it sure did look like a plug-and-play.  Anyone have ideas?
#2 DurhamAppliance
    Sho' Nuff Chozin
  • 1,737 posts
Posted 31 December 2012 - 11:27 AM
Check and provide a complete model number. Shooting in the dark here but If you changed the timer then you more than likely have a relay problem. The relay is the likely suspect especially if the dryer continues to run even with the door open. Btw does this occur in every setting?
Edited by DurhamAppliance, 31 December 2012 - 11:34 AM.
#3 DanInKansas
DanInKansas
    Sōhei
  • 157 posts
Posted 31 December 2012 - 11:57 AM
Dammit -- can't figure out how to edit the topic.  Model number is 110.60612990.
The endless buzzer and the continued spin does happen in every cycle.
#4 DurhamAppliance
    Sho' Nuff Chozin
  • 1,737 posts
Posted 31 December 2012 - 12:27 PM
Ok....with this model...if timer is okay, check the resistor connected to timer.... http://www.repaircli...r/279872/469773
Edited by DurhamAppliance, 31 December 2012 - 12:30 PM.
#5 DanInKansas
DanInKansas
    Sōhei
  • 157 posts
Posted 31 December 2012 - 01:25 PM
Resistor test at 4,950 ohms.  Ref chart says 5,000, so that seems within tolerance.
#6 RegUS_PatOff
  • 30,216 posts
Posted 31 December 2012 - 02:19 PM
Timers are usually not interchangeable
For model 110.60612990 you should have
Timer 3977678
(if nothing else has been substituted)
http://www.repaircli...?R=154&N=548512
#7 DurhamAppliance
    Sho' Nuff Chozin
  • 1,737 posts
Posted 31 December 2012 - 06:41 PM
Certainly the timer was scrounged from an identical model, right??
#8 kdog
    RoughShod
  • 7,428 posts
Posted 31 December 2012 - 07:04 PM
Edited title
Check for shorted push to start switch
http://www.repaircli...er=110.60612990
#9 DurhamAppliance
    Sho' Nuff Chozin
  • 1,737 posts
Posted 31 December 2012 - 07:48 PM
yeah, i believe the relay is incorporated in the start switch here. More than likely his problem ruling out timer.
Edited by DurhamAppliance, 31 December 2012 - 07:48 PM.
#10 kdog
    RoughShod
  • 7,428 posts
Posted 31 December 2012 - 07:52 PM
No relay, just a pair of contacts - known to weld together providing a path to buzzer through contacts meant to be "momentary"
#11 DanInKansas
DanInKansas
    Sōhei
  • 157 posts
Posted 31 December 2012 - 11:17 PM
I did double-check the timer, and it was the same part number. I hadn't thought about a bad push to start switch!  I will check that first thing on  January 2nd.  Happy New Year and thanks to all of you!
#12 RegUS_PatOff
  • 30,216 posts
Posted 31 December 2012 - 11:45 PM
... The unit reaches the end of the cycle, begins to buzz and does not stop buzzing.  Drum does not stop turning.
Does the Timer continue to run into the next Cycle ?
#13 DanInKansas
DanInKansas
    Sōhei
  • 157 posts
Posted 01 January 2013 - 09:57 AM
Good question.  No, timer does not advance.  Stays at the "end of cycle" mark.  Buzzer continues to sound and drum continues to turn.
#14 Samurai Appliance Repair Man
  • 24,243 posts
Posted 01 January 2013 - 10:42 AM
Apprentices may edit their own posts but only Grand Master Funks and Admins can edit topic titles.  Looks like Grand Master kdog has you covered.   :thumbsup:
#15 RegUS_PatOff
  • 30,216 posts
Posted 01 January 2013 - 11:05 AM
... timer does not advance.  Stays at the "end of cycle" mark.  Buzzer continues to sound and drum continues to turn.
I can't find a wiring diagram for that model,
(unless you have one you could scan & upload somewhere)
but all the Dryer Timers I can remember, disconnect the Drum Motor and Buzzer when in the "end of cycle" OFF mark
#16 DurhamAppliance
    Sho' Nuff Chozin
  • 1,737 posts
Posted 01 January 2013 - 02:08 PM
Ok....analyzing Senseis Reg and Kdogs questions...would it be fair to assume a bad start switch can prevent a timer from advancing to the "off" position? If so...did I snatch a small pebble?
Edited by DurhamAppliance, 01 January 2013 - 02:09 PM.
#17 RegUS_PatOff
  • 30,216 posts
Posted 01 January 2013 - 02:26 PM
... when the Dryer Cycle is finished ...
... cycles to OFF and does not continue ...
#18 DanInKansas
DanInKansas
    Sōhei
  • 157 posts
Posted 03 January 2013 - 05:58 PM
I know this topic is marked as "answered" but the timer is the same, so that's not our issue.  Also, the PTS switch is correct.
Anyone have the instructions to the motor installation?  I remember ditching those when I saw the harness was a straight connection and that was probably a bad idea.
#19 kdog
    RoughShod
  • 7,428 posts
Posted 03 January 2013 - 07:53 PM
It was the Start Switch that solved your issue ??
Moron Motor Wiring here: http://www.appliance...otor-change.php
#20 RegUS_PatOff
  • 30,216 posts
Posted 03 January 2013 - 08:09 PM
1) Does the Timer reach the OFF position by itself ?
OR
2) if you turn the Timer to the OFF position, does the Drum and Buzzer turn OFF ?
