Kenmore dryer 110.60612990 -- doesn't stop
27 replies to this topic
#21 DurhamAppliance
    Sho' Nuff Chozin
  • 1,726 posts
Posted 03 January 2013 - 09:11 PM
It was the Start Switch that solved your issue ??
Yeah....what does "the pts switch is correct" mean? "Correct" as in the original part is good ? Or "correct" as in a bad PTS was the correct answer/problem?
#22 DanInKansas
DanInKansas
    Sōhei
  • 157 posts
  • Flavorite Brew:Blue Moon or Lion Imperial or Shiner Bock
Posted 03 January 2013 - 09:37 PM
Moron Motor Wiring here: http://www.appliance...otor-change.php
 I'm sorry, I was unclear.  The start switch is fully open when it's supposed to be and has no resistance when closed.  The switch is also not shorting.
#23 DurhamAppliance
    Sho' Nuff Chozin
  • 1,726 posts
Posted 03 January 2013 - 10:17 PM
That solves it then. Subject to your testing skills, you have one of the following problems:
1: Bad wiring
2: Gremlins
My immeasurable knowledge and immense experience suggest problem #2
#24 RegUS_PatOff
  • 30,203 posts
Posted 03 January 2013 - 10:26 PM
... The unit reaches the end of the cycle
1) Does the Timer reach the OFF position by itself ?
OR
2) if you turn the Timer to the OFF position, does the Drum and Buzzer turn OFF ?
#25 DanInKansas
DanInKansas
    Sōhei
  • 157 posts
Posted 03 January 2013 - 10:33 PM
I will check that out tomorrow and report.
#26 DurhamAppliance
    Sho' Nuff Chozin
  • 1,726 posts
Posted 03 January 2013 - 10:41 PM
The unit reaches the end of the cycle, begins to buzz and does not stop buzzing. Drum does not stop turning.
One of the delivery guys scrounged a timer out of a scrap unit and installed that, with the same results.
"Reaches the end" suggests that the timer moves...
In addition to Sensei Reg's 2nd question, please find out and answer the following, if possible.... Why was the scrapped unit scrapped? Our assumption, despite the odds, that the scrapped unit didn't have the same problem may be incorrect. Therefore, the previously selected "best" answer may be exactly that.
Edited by DurhamAppliance, 05 January 2013 - 07:04 AM.
#27 DanInKansas
DanInKansas
    Sōhei
  • 157 posts
Posted 04 January 2013 - 01:33 PM
1: Bad wiring
2: Gremlins
My vast sophomore experience suggests #1, i.e., "pilot error.
OR
Timer does not reach the "off" position without some help. Timer advances down to the end of the colored bar on the front but does not hit "off" by itself. While the timer is stalled, the motor continues to run and the buzzer continues to sound.
Edited by DanInKansas, 04 January 2013 - 01:33 PM.
#28 RegUS_PatOff
  • 30,203 posts
Posted 04 January 2013 - 02:04 PM
That changes things ..
but unless someone can post a wiring diagram, I can't help
It may be one of these numbers
3406691
3406758
