110.24642300 Kenmore Automatic washer
Softner Dispenser
4 replies to this topic
#1 rolandvz71
rolandvz71
    Sōhei
  • Chief Appliantologist
  • 194 posts
  • Flavorite Brew:Sweet Sun Tea w/lemon
Posted 31 December 2012 - 11:38 AM
ok running down a softener dispenser and I know I have the model # and all ---but I have found another one that looks just like it.....price is different so trying to save some $$ here. I know that some times parts to cross-ref each other.
So my questions is are these 2 parts one in the same?
8533252 & 8528278
#2 RegUS_PatOff
  • 30,190 posts
Posted 31 December 2012 - 01:58 PM
from AppliancePartsPros Q&A
for Model Number 110.24904200 < newer model
Owners Manual says the <newer / cheaper> FABRIC SOFTENER DISPENSER
(part # 8528278) should have a "BLUE" LOCKING RING
which is not referenced or pictured with the replacement part information.
Please let me know if the locking ring comes withe the dispenser or has to be order separately?
Answer: at one point there were two different softner dispensers.
Apparently the manufacturer has substituted the dispenser with the locking ring to the dispenser without the locking ring.
Read more:
Part number: 8528278
#3 rolandvz71
rolandvz71
    Sōhei
  • 194 posts
Posted 31 December 2012 - 02:28 PM
Wow this little booger starting to test me!
I did not have a locking ring, but who's to say there should be one there. This machine was saved from salvage all it had was a bad clutch, but looks like now I have a softer dispenser issue. I have no idea if it needs a locking ring or not. All I do know is the one that came w/the washer has a broken tab that appears like it will not stay in place due to the tab being broken.
Looks like I might have to just replace w/a simple cap....no softener dispenser.
#4 RegUS_PatOff
  • 30,190 posts
Posted 31 December 2012 - 02:34 PM
the "newer" models require the Locking Ring (included with the "newer" / cheaper Dispenser)
May not be required to install the new Locking Ring on your "older" model...
For only $ 7, may be able to purchase at local appliance parts store and try it /compare it and or return it ...
Let us know
#5 kdog
    RoughShod
  • 7,428 posts
Posted 31 December 2012 - 07:14 PM
The push in dispenser will not work with this as it is from a thinner agitator
The one you need is this:  http://www.repaircli...er=110.24642300
Fabric-Softener-Dispenser-8533252-007076
Hey, Brutha, can you spare a dime for a cuppa joe ? http://web.me.com/zenzoidman/kdog/
Le Chien Rouge
