Whirlpool LSW9245EQ agitator - basket misalignment
5 replies to this topic
#1 gayle2c
gayle2c
  • Appliantologist
  • 3 posts
Posted 31 December 2012 - 11:45 AM
My laundry is being shredded.  Not the dryer - the latest victims are table linens that have only gone through a soak and a wash cycle.
There is an uneven gap between the bottom of the agitator and the inner basket.  Looking from the front of the washer, I have a 3/8" gap at 9:00 and a 3/4" gap at 3:00.
When I remove the agitator, rotate it, and replace it onto the agitator shaft, the larger 3/4" gap remains at 3:00.
The washer agitates and spins as it should.  No alarming noises or leaks.
Tho it seemed to me that it was an alignment problem, I started on the inside of the basket first.  The bottom of the agitator isn't warped; when I remove it, it's level and circular.  I've cleaned all the soap deposits on the agitator shaft and inner basket.  The 4 "buttons" on the shaft move freely in and out.
Once I remove the cabinet, where do I start looking?
Thanks.
#2 kdog
    RoughShod
  • 7,433 posts
Posted 31 December 2012 - 07:39 PM
Get more info here and pay close attention to the drive block
  • 24,698 posts
Posted 01 January 2013 - 10:33 AM
Part link for the drive block ==> http://www.repaircli...ock/389140/2858
#4 gayle2c
gayle2c
  • Appliantologist
  • 3 posts
Posted 02 January 2013 - 07:26 AM
Thank you both.  I'm traveling and will try this when I get back.
#5 gayle2c
gayle2c
  • Appliantologist
  • 3 posts
Posted 17 March 2013 - 07:32 AM
So...I replaced the drive block, and replaced the agitator dogs while I was at it.  Still out of alignment - same gap, same place.
But, I noticed that there was quite a bit of rust on one side of the agitator shaft.  I sanded it down, and the problem was fixed, albeit temporarily.  I know the agitator shaft and I guess the complete gearcase will need to be replaced next.  Hubby says no - get a new washer.  I say we'll see.  There's nothing on the market that I really want.
Thanks.
#6 Scottthewolf
Scottthewolf
    Senpai
  • 1,933 posts
Posted 20 March 2013 - 05:37 PM
FIX IT! This washer will still outlast any of the new washers on the market today.
Scott Wolf
0 members, 1 guests, 0 anonymous users
