VSD2304J00WW GE Dishwasher
5 replies to this topic
#1 Strathy
Strathy
    Kohai
  • 381 posts
  • Flavorite Brew:DP.
Posted 31 December 2012 - 02:12 PM
This is justa base model run of the mill GE, but it has me stumped. B4 I pull it apart any further, do ya'll have any suggestions? Leaving white residue and small food particles on the dishes especially the upper rack. Checked soap, water temp, etc. Nothing really obvious there. The spray tower telescope seems to be going up and the spray arm is definitely turning. The spray tower is chewed up a bit - not sure what might have caused that, but it still seems to be going up properly with the water pressure. I'm not super familiar with these. Anything common that I should check?
Neighbour's Appliance Service
Servicing Southern Manitoba, Canada
#2 RegUS_PatOff
  • 30,188 posts
Posted 31 December 2012 - 02:20 PM
water level is OK ?
#3 Strathy
Strathy
    Kohai
  • 381 posts
Posted 31 December 2012 - 02:24 PM
Seemed normal to me. Lots of water pressure coming in.
#4 tpoindexter
tpoindexter
    Sōhei
  • 241 posts
  • Flavorite Brew:Beamish
Posted 31 December 2012 - 04:14 PM
Should be able to place a cup (approx. 8 oz.) in the top basket and run for about 60 seconds. If the glass fills up then it's dispensing water sufficiently.
Test
  • 24,199 posts
Posted 01 January 2013 - 10:10 AM
Are you sure the model number is "VSD..." and not "GSD..."?
#6 Strathy
Strathy
    Kohai
  • 381 posts
Posted 01 January 2013 - 10:40 AM
Took the number right from the model tag ... pretty sure it is correct.
