Whirlpool Duet HT Front loader (9 years old) flooding
6 replies to this topic
#1 Frumby
Frumby
  • 10 posts
Posted 02 January 2013 - 05:09 PM
Apparently, water is backfilling into the tub and flooding through the door.  The washer was not in use and had not been used for a day when this occurred.  Any thoughts would be helpful.
Frumby
The Colonel
#2 RegUS_PatOff
  • 30,264 posts
Posted 02 January 2013 - 05:48 PM
sounds like a leaky Water Valve
#3 jumptrout
jumptrout
  • 1,138 posts
  • Flavorite Brew:Coors Light
Posted 02 January 2013 - 07:01 PM
Does this 9 year old washer have a model number?
If so,we can tell you the part number.
#4 Frumby
Frumby
  • 10 posts
Posted 02 January 2013 - 07:16 PM
Sorry, I should have known better:  Model #GHW9400PL0
The Colonel
#5 RegUS_PatOff
  • 30,264 posts
Posted 02 January 2013 - 07:26 PM
http://www.repaircli...?R=154&N=906483
#6 Scottthewolf
Scottthewolf
    Senpai
  • 1,917 posts
Posted 02 January 2013 - 10:29 PM
Seems to be more common in these washers than other brands.  I've had 3 of these  where the water valve was not closing completely and not completely shutting the water off even when the machine was  turned off and unplugged.
Scott Wolf
#7 Frumby
Frumby
  • 10 posts
Posted 03 January 2013 - 07:11 AM
Thanks gentlemen. I've ordered the part and it is on the way. I actually thought that it was drain pump not working. Obviously misdiagnosed when the washer had not been used in over a day and water began leaking from the door. Just another lesson learned. Thank you again.
The Colonel
The Colonel
