GE Bottom Freezer-Model#GDL20KCSBS, Defrost System Fix?
11 replies to this topic
#1 AlexM
AlexM
    Sōhei
  • Chief Appliantologist
  • 241 posts
  • Flavorite Brew:Root Beer
Posted 02 January 2013 - 11:34 PM
This GE Bottom Freezer was not cooling in the fresh food section. When I arrived the compressor, evap fan, condenser fan was all running strong. The evaporator was froze over, so I defrosted it and the heater checked out fine, so I put a new limit on and a new thermister, put it all back together and plugged it back in, and nothing worked but the lights.  Here are some of my many questions:
1. I was told at one time to always change out the old style thermisters with the black end where the wires go in, is this true because I did put a new thermister on this one.?
2. The defrost limit that I replaced had the symetrical clip that was installed on one of the support fins for the evaporator.  I replaced the original with a limit that had the same L140-30F markings as the original, but had the clip that goes on the evaporator direct, so I did that, is that acceptable? or do I need to order the same one and install it on the support fin?
3. How do you get the control panel off the top of the fresh food section? I removed the light cover and two screws, then broke one of three plastic studs and then put the screws back in and left it.  What hold that all on and how do you get it removed.
4. When i couldnt get the unit started back up I cleaned up my tools and made a trip to the truck, 20 minutes after I plugged it in the compressor sounded like it was running but nothing else.  does it normally take this long to get the unit started again after defrosting?
#2 AlexM
AlexM
    Sōhei
  • 241 posts
Posted 03 January 2013 - 08:39 AM
Might someone have the service manual? thanks in advance.
  • 24,356 posts
Posted 03 January 2013 - 08:57 AM
Minimanual uploaded here ==> http://appliantology...anual-31-51651/
Yes, replace ALL old thermistors with the new ones.
Will probably be fine. I've made many similar substitutions with no call-backs.
Did you slide the control assembly forward and then out? They can feel stuck from the urethane foam insulation in the cabinet.
Try putting the muthaboard into forced defrost and see if the heating element fires up ==> http://fixitnow.com/...-the-quick-fix/
#4 AlexM
AlexM
    Sōhei
  • 241 posts
Posted 03 January 2013 - 09:23 AM
So let me get this straight, while the refrigerator is plugged in and the evaporator is cold clip a wire from the 'Line' terminal to the 'Defr' terminal in the photo? The reason I'm scared is because I fried a board by messing around with a power cord/jumper and what not.  I was very tramatized.
#5 DurhamAppliance
    Sho' Nuff Chozin
  • 1,754 posts
Posted 03 January 2013 - 09:41 AM
Question 1.....yes.. this is a recommendation from GE but under the circumstances, testingt he original thermistor would help rule out it as the cause
Question 2...not a problem....again testing it before replacement would help your diagnosis
If your were able to rule out heater, sensor and limit, then you would know if a new board is needed. Schematics on this model is sketchy but the board should be located on the back of the fridge. It may not be necessary to access controls in ff section. If the compressor is running, your fans should be running. This should not be a user interface issue.
You may have to hold down the light switch to hear fan running with freezer drawer open. Double check your connections and test fans at the board.
  • 24,356 posts
Posted 03 January 2013 - 11:32 AM
Just use an insulated alligator clip jumper wire when you do the defrost test and you'll be fine. You may see a little spark when you connect the second clip but that's normal. Just keep a steady hand. No worries.
#7 AlexM
AlexM
    Sōhei
  • 241 posts
Posted 03 January 2013 - 01:48 PM
Sounds shockingly easy.
#8 DurhamAppliance
    Sho' Nuff Chozin
  • 1,754 posts
Posted 03 January 2013 - 05:16 PM
I oftened wondered if that spark would damage the board. I became a girly-man and always unplug fridge first, then plug it back in after jumping.
  • 24,356 posts
Posted 03 January 2013 - 06:06 PM
That works, too!   :dazzler:
#10 kdog
    RoughShod
  • 7,428 posts
Posted 03 January 2013 - 08:14 PM
Always a good idea, safety first - Stayin Alive
#11 Scottthewolf
Scottthewolf
    Senpai
  • 1,919 posts
Posted 03 January 2013 - 10:08 PM
Ahnold the idiot caught cheating on his wife and even had a kid with his mistress. Great way to ruin your career in politics.  That's why he's back to being an actor again.
Scott Wolf
#12 kdog
    RoughShod
  • 7,428 posts
Posted 05 January 2013 - 02:14 AM
Which is where he belongs anyway - look at his choice of tie colors, you have to strain to see that he's even wearing one - nothing speaks power like light yellow on white. He's in 2 movies coming out this year. Currently reading his latest book.
