GE Refrigerator Model# PCF23MGWABB, Ice Auger Issues
3 replies to this topic
#1 AlexM
AlexM
    Sōhei
  • Chief Appliantologist
  • 240 posts
  • Flavorite Brew:Root Beer
Posted 02 January 2013 - 11:44 PM
The ice maker is producing plenty of ice, when you go for crushed or regular ice cubes in the door the auger motor runs for a second then shuts off.  During this, for a fraction of a second the display flashes '0' and then stays blank. I checked the actual ice bin and the cork screw turns freely and I operated the auger without the bin in and the auger does the same thing. I suspect I need a new dispensor control board P/N WR55x10899 and or front panel P/N WR55X10861.  The front panel part number needs to be black,how can i confirm this?
#2 AlexM
AlexM
    Sōhei
  • 240 posts
Posted 03 January 2013 - 08:35 AM
Maybe someone has the user manual? Thanks in advance.
  • 24,321 posts
Posted 03 January 2013 - 08:41 AM
I don't have the service manual but can get the minimanual (basically, the schematic and specs) if that would help.
Check the wire harness connector at the bottom of the freezer door hinge.  If wet, corroded or mangled, that'll be the problem.
#4 AlexM
AlexM
    Sōhei
  • 240 posts
Posted 18 January 2013 - 01:25 AM
Well I went back today and the home owner claimed that the auger works on occasion.  Didn't work for me.  I checked the wire harness at the bottom, cleaned it with rubbing alchohol.  Also checked the harness on the auger motor, seemed fine.  When I depress the ice dispenser lever on the front of the door, the flap opens, but nothing happening with auger motor.  When I switch back and forth between crushed ice and cubes, the cylinoid doesn't activate either?  Is this a problem in the front of the door?
