Frigidaire Refrigerator PHS39EJSS1
tpoindexter
  • Replies 4
  • tpoindexter
Thank you for the file. Can you give me alittle more insight on the problem I'm having?
Complaint: Temperature display is blank. Lights and water dispenser works. Beeping continuosly. Doors closed. Should I post questions in the forum?
