Stove heats/ no display FFEF3015LSD
1 reply to this topic
#1 BigD69
BigD69
  • 6 posts
  • Flavorite Brew:Fat Tire draft
Posted 03 January 2013 - 08:13 PM
Mod#FFEF3015LSD oven and burners hot no
Display.control panel?
#2 kdog
    RoughShod
  • 7,433 posts
Posted 03 January 2013 - 08:29 PM
Blank display:
If the display on the oven control is blank and the range
connected to electrical power:
1. Go to the back of the control and measure the
voltage drop between terminal L1 and neutral. If the
meter reads line to neutral voltage (120VAC) the
control is defective. If the meter reads zero the
wiring in the range is defective.
An ES200 control - manual is here
Link to Control (if needed):
http://www.repaircli...ber=FFEF3015LSD
Oven-Control-Board-316557114-00682926.jp
