#1
Posted 05 January 2013 - 02:27 PM
I have a GE Profile oven which displayed the dreaded "F0" error. With wisdom gleaned from this forum, I ordered a new clock from the "RepairClinic", then bravely installed the new part. I briefly was stymied by a new error reading "Loc rEF" but the master again, in his wisdom, provided the answer to enable the new clock and touchpad to communicate.
All seemed well, with the touchpad responding correctly to all inputs. However, when the oven is started, the vent fan no longer starts up. The oven heats as it should, but the fan does not come on.
How did I fail master? Is this a new problem, or does it indicate the connections were not made properly?
#2
Posted 05 January 2013 - 02:36 PM
Oven model number ?
- kdog likes this
#3
Posted 05 January 2013 - 02:38 PM
#4
Posted 05 January 2013 - 04:22 PM
#5
Posted 05 January 2013 - 04:26 PM
#6
Posted 05 January 2013 - 05:03 PM
Cooling Timing Parameters JGS968
The cooling fan comes on when the oven is on.
If the temperature is set over 300°F and the oven is turned off,
the fan will remain on until the temperature drops below 300°F or 85 minutes has elapsed.
#7
Posted 05 January 2013 - 05:17 PM
For future reference, here's the service manual to your range ==> http://appliantology...manual-31-9105/
- kdog likes this
#8
Posted 05 January 2013 - 10:15 PM
Many thanks for the link to the repair manual master. I am honored.
#9
Posted 05 January 2013 - 10:54 PM
Correction, the cooling fan comes on when the oven reaches approximately 150 degrees F.
.. may have changed with all the "universal" GE replacement Oven Controllers
originally:
Cooling Timing Parameters J2S968
If the temperature is set over 175°F and the oven is turned off,
the fan will remain on until the temperature drops below 175°F or 85 minutes has elapsed.
Cooling Timing Parameters JGSP48
If the temperature is over 300°F and the oven is turned off,
the fan will remain on until the temperature drops below 300°F.
Also tagged with one or more of these keywords: GE Oven
Appliantology Appliance Repair Forums →
The Kitchen Appliance Repair Forum →
GE double electric oven JTP27BOA5BB temperature issueStarted by Skippy424242, 20 Sep 2011 |
