MAH2400AWW FRONT LOAD WASHER
3 replies to this topic
#1 cityboysrus
cityboysrus
    Ikkō-ikki
  • Appliantologist
  • 34 posts
Posted 05 January 2013 - 08:15 PM
OK NO SCHEMATIC :rocker:  WASHER WONT WASH OR SPIN. I DISCONNECTED THE QUICK CONNECT FROM THE MOTOR AND GROUNDED ONE LEAD OF MY METER, THE OTHER LEAD I CHECKED EACH MALE TERMINAL(ON THE MOTOR) WITH THE WASHER IN SPIN TO SEE IF THE BOARD IS SENDING 120 VAC TO THE MOTOR. I VERIFIED 120 VAC. WITHOUT A SCHEMATIC OR TECH SHEET FOR THIS MODEL DOES REPLACING THE MOTOR SOUND CORRECT OR IS THERE SOME TEST ON THE BOARD I MISSED WITHOUT THE TECH SHEET BEING PRESENT.
LASTLY THE BOARD SENDS 120 VAC TO INLET VALVE
TO THE PUMP, AND DOOR LOCK
AS WELL AS MOTOR THAT'S WHAT'S MAKING MR LEAN 85% TO THE MOTOR, BUT WITH NO PAPERWORK JUST MY LUCK THE BOARD COULD BE BAD ON THE MOTOR CIRCUIT.
Edited by cityboysrus, 05 January 2013 - 08:18 PM.
#2 RegUS_PatOff
  • 30,708 posts
Posted 05 January 2013 - 08:23 PM
hard to verify the Motor that way ..
http://appliantology...compact-washer/
#3 cityboysrus
cityboysrus
    Ikkō-ikki
  • Appliantologist
  • 34 posts
Posted 05 January 2013 - 11:05 PM
YOU ROCK!!!! THANKS FOR THE TECH SHEET!!!!! I FOUND IT!!!!! PAGE 2 UNDER NO TUMBLE SECTION SHOWS MOTOR RESISTANCE. PINS 8 & 9 ARE OPEN I SHOULD GET 3.6 OHMS PINS 1 & 10=1.2 OHMS AND 5 & 10=1.4 OHMS. I TOOK THE OLD MOTOR WITH ME ON THIS ONE, AND IT WORKED OUT YOU GUYS SAVED ME FROM PURCHASING BOTH ON MONDAY BEFORE I WENT BACK TO COMPLETE THIS JOB!!!! :rocker:
Drive motor part link ==> http://www.repaircli...mber=MAH2400AWW
Edited by Samurai Appliance Repair Man, 07 January 2013 - 07:44 PM.
Added part link to drive motor.
#4 cityboysrus
cityboysrus
    Ikkō-ikki
  • Appliantologist
  • 34 posts
Posted 07 January 2013 - 01:49 PM
  • THAT DID IT WASHER WORKS LIKE A CHARM!!!! :rocker: THANKS AGAIN FELLAS!!!!
