Programming Maytag Fridge
63 replies to this topic
#1 arturo7
arturo7
    Ikkō-ikki
  • 22 posts
  • Flavorite Brew:Ballast Point Sculpin
Posted 06 January 2013 - 04:42 PM
Hello,
I just replaced the HV board on my Matag fridge, model MBR2562HES.
Trying to program the new board but the touchpad will not accept any input.
What gives?
thanks
#2 RegUS_PatOff
  • 30,201 posts
Posted 06 January 2013 - 05:21 PM
how far does it get ?
does it display the PE ?
1) Open the Fresh Food door and press and hold the Door Alarm Keypad DoorAlarm
2) Press and hold Freezer Temperature Down Keypad -
3. Release the Door Alarm Keypad DoorAlarm and wait 3 seconds
(keep holding the Freezer Temperature Down Keypad)
4. The control will display PE to indicate the programming mode.
#3 arturo7
arturo7
    Ikkō-ikki
  • 22 posts
Posted 06 January 2013 - 05:26 PM
Thanks for the quick reply.
The display reads PEO OOO
I have the programming code sequence, but the touch pad does not repond.
#4 DurhamAppliance
    Sho' Nuff Chozin
  • 1,718 posts
Posted 06 January 2013 - 05:40 PM
Could you enter into programming or test mode with original board? Btw, why did you replace the board?
#5 KurtiusInterupptus
KurtiusInterupptus
    B.M.F.
  • 1,463 posts
  • Flavorite Brew:Killians Red
Posted 06 January 2013 - 06:05 PM
I don't know how to say this except to tell you to keep doing the key dance as accurately as possible...it has taken me as many as 15 -20 trys to enter the programing mode...a real pita!
#6 arturo7
arturo7
    Ikkō-ikki
  • 22 posts
Posted 07 January 2013 - 11:44 AM
Sho- The fridge was running, but it would not cool. Same with the freezer. Everything I read indicated the problem was the HV board.
BMF- What is the secret to the "dance?"
#7 DurhamAppliance
    Sho' Nuff Chozin
  • 1,718 posts
Posted 07 January 2013 - 12:00 PM
I have never had a problem programming these board but Kurtius has probably done more of them. Did you try diagnostics/programming with the original board? If you could, then we know you are doing the "dance" correctly and it would rule out a wiring problem. Process of elimimation is one of the best tools in appliance repair.
Edited by DurhamAppliance, 07 January 2013 - 12:21 PM.
#8 KurtiusInterupptus
KurtiusInterupptus
    B.M.F.
  • 1,463 posts
Posted 07 January 2013 - 12:08 PM
Master Reg has posted the dance a few posts back...re-read and follow explicitly.
No cool huh? Have you made sure the compressor is running? If not , is it getting 120vac from control? Known start relay issues with these...
#9 arturo7
arturo7
    Ikkō-ikki
  • 22 posts
Posted 08 January 2013 - 11:08 AM
BMF, I have a copy of the procedure. You seemed to be implying that there was some special way to perform it.
The compressor was running.
How do I do this?
#10 DurhamAppliance
    Sho' Nuff Chozin
  • 1,718 posts
Posted 08 January 2013 - 07:51 PM
You can program your original board using the same key combination for your new board.If I am not mkstaken, diagnostic mode is entered using the fresh food keys as oppose to the freezer keys. Do you have the tech sheet or service manual?
Edited by DurhamAppliance, 08 January 2013 - 07:56 PM.
#11 arturo7
arturo7
    Ikkō-ikki
  • 22 posts
Posted 08 January 2013 - 09:17 PM
The control buttons do not work with the old board either.
I have a tech sheet. It says to use the freezer down key. There are no fresh food keys.
#12 DurhamAppliance
    Sho' Nuff Chozin
  • 1,718 posts
Posted 09 January 2013 - 04:43 AM
Ok.... If touchpad does not work with neither boards, something is interfering with communication between board and touchpad. You may need another touchpad but first make sure the ribbon is seated properly. Check you tech sheet for a touchpad test. Have you tested/replaced thermistors?
But before you start buying more stuff, an accurate diagnosis of your problem is needed. You said the fridge is running but not cooling, please explain. Fans running? , frost build up? Compressor running? What are the temps?
Edited by DurhamAppliance, 09 January 2013 - 05:03 AM.
#13 arturo7
arturo7
    Ikkō-ikki
  • 22 posts
Posted 11 January 2013 - 07:21 PM
DA, thanks for you help.
Where can I find tech sheets? Maytag's sight only has owner's manual and parts list.
Where can I find the thermisters and how are they tested?
With the old board the compressor runs, fan runs. Not cold enough for frost build up. Temps are in the mid 60's. This is what the control has as the set temps, and they will cannot be changed.
Edited by arturo7, 11 January 2013 - 07:24 PM.
#14 RegUS_PatOff
  • 30,201 posts
Posted 11 January 2013 - 07:46 PM
I have a tech sheet
:kopkrab:
#15 arturo7
arturo7
    Ikkō-ikki
  • 22 posts
Posted 11 January 2013 - 08:12 PM
Nice catch sensei.
To clarify, I have a tech sheet for the the HV board but not the fridge.
#16 RegUS_PatOff
  • 30,201 posts
Posted 11 January 2013 - 08:34 PM
MBR2562HES
Maytag says these are your service info:
http://appliantology...e-bottom-mount/
#17 DurhamAppliance
    Sho' Nuff Chozin
  • 1,718 posts
Posted 11 January 2013 - 11:10 PM
"fresh food keys" = Refrigerator keys
#18 kdog
    RoughShod
  • 7,428 posts
Posted 11 January 2013 - 11:12 PM
AKA - Beer Compartment
#19 arturo7
arturo7
    Ikkō-ikki
  • 22 posts
Posted 12 January 2013 - 01:31 PM
Thank you, sensei
#20 arturo7
arturo7
    Ikkō-ikki
  • 22 posts
Posted 13 January 2013 - 02:08 PM
To which ribbon are you referring?
The control panel remains unresponsive. If I put the old board back in the fridge fires up but the temps cannot be changed. Is there a way to test the control panel? How do I access it?
