Programming Maytag Fridge
63 replies to this topic
#21 DurhamAppliance
    Sho' Nuff Chozin
  • 1,746 posts
Posted 13 January 2013 - 05:22 PM
http://www.repaircli...7005439/1126103
Not sure about the test... I did not see one listed on the tech sheet.
I suggest replacing thermistors, see what happens then replace touchpad. However, this is subject to your ability to perform "the dance" and the accuracy of your diagnosis.
btw have you looked at your evaporator and is your compressor warm and vibrating?
Edited by DurhamAppliance, 13 January 2013 - 05:53 PM.
#22 arturo7
arturo7
    Ikkō-ikki
  • 22 posts
  • Flavorite Brew:Ballast Point Sculpin
Posted 22 January 2013 - 08:18 PM
Been on the road for a few days. Good thing I have a garage fride to keep my beer cold...
Where do I find the thermisters?
How can I remove the touchpad, and can it be tested?
#23 tpoindexter
tpoindexter
    Sōhei
  • 241 posts
  • Flavorite Brew:Beamish
Posted 22 January 2013 - 08:32 PM
MBR2562HES
Maytag says these are your service info:
http://appliantology...e-bottom-mount/
Page 32 in 3rd link
Test
#24 DurhamAppliance
    Sho' Nuff Chozin
  • 1,746 posts
Posted 23 January 2013 - 11:01 PM
You switched out the HV board but your problem may be with the jazz board, part no. W10207861. Sounds like the user interface on that board is shot.
Edited by Samurai Appliance Repair Man, 29 January 2013 - 12:29 PM.
Added part link.
#25 Samurai Appliance Repair Man
  • 24,321 posts
Posted 24 January 2013 - 09:54 AM
Jazz control board ==> http://www.repaircli...mber=MBR2562HES
User-Control-and-Display-Board-W10207861
#26 arturo7
arturo7
    Ikkō-ikki
  • 22 posts
Posted 29 January 2013 - 10:35 PM
Alright, i have the light cover off but I can't figure out how to remove the control board housing. The drawing on page 32 shows release tabs but doesn't give any indication of how they actuate. Does the cover come down or go forward?
Maybe I'm just being overcautios for fear of breaking it...
#27 DurhamAppliance
    Sho' Nuff Chozin
  • 1,746 posts
Posted 30 January 2013 - 12:42 AM
Okay.... Remove top and next shelves... Get a flat blade screwdriver and you are going to have to lean backwards in the fridge. Look up at the back of the housing and you will see two slots. The clips are shaped like an upside down "L" Push the screwdriver in the slot at slightly more than a forty-five degree angle. Some force may be required. Do both sides and the housing will pivot down away from you and towards the front.
they say a picture speaks a thousand words. My pictures only speaks four: "I suck at drawing."
Edited by DurhamAppliance, 30 January 2013 - 01:13 AM.
#28 arturo7
arturo7
    Ikkō-ikki
  • 22 posts
Posted 30 January 2013 - 02:06 AM
Thanks, DA. I'll give it a shot.
Dear Mods, I think your "answered" tag is a bit premature. The fridge isn't running yet...
#29 kdog
    RoughShod
  • 7,428 posts
Posted 30 January 2013 - 02:11 AM
Marked it unsolved - let us know
#30 arturo7
arturo7
    Ikkō-ikki
  • 22 posts
Posted 13 March 2013 - 03:12 PM
Finally home for a couple days. I was able to replace this board but the problem persists...
#31 telefunkenu47
telefunkenu47
    Kohai
  • 322 posts
Posted 13 March 2013 - 06:29 PM
Is there a GFI at the outlet where you plug the fridge in? How bout the breaker that the fridge is on? is it a GFI type? Is  the fridge on a gfi circuit,say, behind the coffee maker per chance? nI have seen similar  scenario's play out over the years. Its the first thing you want to  rule out.
Even root canal is easy...if you're a dentist...
#32 DurhamAppliance
    Sho' Nuff Chozin
  • 1,746 posts
Posted 14 March 2013 - 01:43 AM
If no GFI problem, you could be in control board - Keypad purgatory.   They may not be communicating  with each other and it can be difficult to tell which one is causing the problem...could be board, ribbon seating, keypad or all three...some call it hell, but it's more like purgatory.  If you got your board from repair clinic, and your old one does the same thing, send the new one back and get a keypad and make sure the ribbon is seated properly.   Did we ever get an answer regarding frost pattern on your evap?
#33 arturo7
arturo7
    Ikkō-ikki
  • 22 posts
Posted 15 March 2013 - 01:10 PM
no frost
#34 arturo7
arturo7
    Ikkō-ikki
  • 22 posts
Posted 15 March 2013 - 01:13 PM
Curious how this could be a connection issue?  The previous board had the same condition. How could the ribbon become unseated w/o removing the cover?
#35 DurhamAppliance
    Sho' Nuff Chozin
  • 1,746 posts
Posted 15 March 2013 - 09:51 PM
a connection issue does not necessarily mean a problem with seating.  Could be a bad ribbon. Connection, in this case, means communication between the keyboard and main board ie they aint talkin wit each other like they should.
#36 arturo7
arturo7
    Ikkō-ikki
  • 22 posts
Posted 25 March 2013 - 11:07 AM
The touchpad has been replaced. Same problem.
Looks like it may have been a bad decision to attempt a DIY fix.
Open for any suggestions or recommendation of a good repair tech in SoCal...
Dear mods, problem still not "answered."
#37 DurhamAppliance
    Sho' Nuff Chozin
  • 1,746 posts
Posted 25 March 2013 - 11:29 AM
Okay....does "same problem" mean that there is no cooling or that you cannot get the user interface to work?  If no cooling, we need to see a picture of your evaporator coils...you said "no frost" but that does not give us sufficient info.
Earlier, I suggested you replaced thermistors. They are cheap enough, was this done?  I have experienced 2 fridges where thermistors caused the display board or access to diagnostic mode not to work. Doesn't make sense and have not had anyone with more electrical knowledge confirm this possibility. All I know is once the bad thermistors were replaced, everything worked. One was a GE and the other was a fridge with a jazz board. The only support I have on this is during Asti training the instructor in the Basic Electricity class talked about an oven model where a bad temp probe caused the display not to work. and a temp probe is nothing but a thermistor. Although when I asked him if the same thing was possible in my situations, he could not confirm it.
But don't give up...never ever give up!
#38 Scottthewolf
Scottthewolf
    Senpai
  • 1,917 posts
Posted 25 March 2013 - 05:58 PM
The control panel  is nothing more than a display panel on these models, the Jazz board has the actual buttons on it. Chances are you don't have the Jazz board fully seated in the display.
Scott Wolf
#39 Samurai Appliance Repair Man
  • 24,321 posts
Posted 26 March 2013 - 08:10 AM
Why did you replace the touchpad?  Or did you actually replace the jazz control board but used the wrong term in your reply?
#40 DurhamAppliance
    Sho' Nuff Chozin
  • 1,746 posts
Posted 26 March 2013 - 08:25 AM
main problem was no cooling and touchpad not responsive. initially replaced a board called the hv board but not the jazz board. then jazz board then touch pad. Im not sure if the problem is still no cooling and non responsive board.
