Programming Maytag Fridge
63 replies to this topic
#41 Samurai Appliance Repair Man
    Shōgun
  • Master Samurai Tech
  • 30,171 posts
Posted 26 March 2013 - 08:33 AM
Domo for the re-cap and clarification, Brother Durham.
#42 arturo7
arturo7
    Ikkō-ikki
  • 22 posts
  • Flavorite Brew:Ballast Point Sculpin
Posted 26 March 2013 - 10:38 AM
The HV board, Jazz board, and touchpad have all been replaced.
At present, the display reads PE0 - 000, but it will not respond to any input.
The original problem was that the temp displays read in the 60's and the control would not respond to any input. Before the HV board was replaced, there was something running, but there was no cooling. Now there is nothing running.
I assume there are 2 thermistors? Anybody have the part numbers?
#43 Moostafa
Moostafa
    Imam
  • The Ayatollah of Appliantology
  • PipPipPipPip
  • 771 posts
  • Flavorite Brew:Poppy Salmagundi
Posted 26 March 2013 - 10:44 AM
Hello, my uncool friend. When you replaced the Jazz Board, did you program in the correct personality code found on the model number tag?
Also, these Jazz Boards are particularly static sensitive. If you failed to observe anti-static precautions or if you handled the board by other than the edges, you may have damaged it upon installation. I once made this mistake with the inverter board for my yak dung and lime juice DC voltage generator. Unfortunately, it was a board scavaged from old Soviet equipment so, unlike parts purchased from your Ameedican RepairClinic, I did not have the option of requesting a free replacement.
Allahu Akbar!
#44 RegUS_PatOff
  • Academy Instructor
  • 33,588 posts
Posted 26 March 2013 - 10:50 AM
... When you replaced the Jazz Board, did you program in the correct personality code found on the model number tag?
:beatnik:
from original post:
... Trying to program the new board but the touchpad will not accept any input.
#45 Moostafa
Moostafa
    Imam
  • PipPipPipPip
  • 771 posts
Posted 26 March 2013 - 11:24 AM
Hello, Regular, my quotable friend. Thank you for pointing out the superfluidity of my suggestion. With the time difference between this forum, which seems to be mostly US time zones, and my own time zone in Kabul, Afghanistan, and my real-world duties sampling our poppy crop, it is difficult for me to keep up with all that transpires in a lengthy topic. In fact, one of my wives has just brought me another sample of the crop to test in the hookah. Please excuse me, I will be gone for a while as this is a time-intensive process. My wives usually get frisky after the crop sampling.
Allahu Akbar!
#46 tpoindexter
tpoindexter
    Senpai
  • Master Appliantologist
  • PipPipPipPip
  • 656 posts
  • Flavorite Brew:Beamish
Posted 26 March 2013 - 04:01 PM
PE 0 00 means you have entered the program mode. There should have been instructions in the box with the jazz board. The number is located on the same label as the model and serial number. It should say code followed by numbers just below voltage and amps on the label.
Edited by tpoindexter, 26 March 2013 - 06:16 PM.
Test
#47 arturo7
arturo7
    Ikkō-ikki
  • 22 posts
Posted 28 March 2013 - 10:24 AM
I have the instructions but the system will not respond to any input.
#48 RegUS_PatOff
  • 33,588 posts
Posted 28 March 2013 - 10:26 AM
may have to post YouTube video of your programing sequence attempt
#49 arturo7
arturo7
    Ikkō-ikki
  • 22 posts
Posted 28 March 2013 - 06:36 PM
I don't have a Youtube account. Plus, if I'm doing it wrong, It would be much better to see someone doing it successfully.
#50 arturo7
arturo7
    Ikkō-ikki
  • 22 posts
Posted 04 April 2013 - 08:34 PM
Picked up a thermistor. If one of them is bad, I'd guess it's in the freezer.
What is involved in changing it?
#51 tpoindexter
tpoindexter
    Senpai
  • PipPipPipPip
  • 656 posts
Posted 04 April 2013 - 08:48 PM
This is the best way for you to get help at this point.
Edited by tpoindexter, 04 April 2013 - 08:49 PM.
Test
#52 DurhamAppliance
    Sho' Nuff Chozin
  • 5,434 posts
Posted 04 April 2013 - 08:54 PM
I would suggest testing all your thermistors first....that may not be your problem, although there is not much left other than incorrect testing sequence.  On second thought, if you only have two thermistors, you can change them quickly without testing and you won't lose much money or time
check out this video...it is a ge so the.only part of interest to you would be the ending where he shows you a simple way to replace thermistors.
www.DurhamApplianceThrift.com
#53 arturo7
arturo7
    Ikkō-ikki
  • 22 posts
Posted 06 April 2013 - 03:41 PM
I think the best way would be for someone to post a video of the correct procedure. I don't have a youtube account.
Edited by arturo7, 06 April 2013 - 03:41 PM.
#54 Samurai Appliance Repair Man
    Shōgun
  • 30,171 posts
Posted 06 April 2013 - 09:29 PM
Create a FREE YouTube account here
#55 tpoindexter
tpoindexter
    Senpai
  • PipPipPipPip
  • 656 posts
Posted 07 April 2013 - 12:27 AM
Test
#56 arturo7
arturo7
    Ikkō-ikki
  • 22 posts
Posted 07 April 2013 - 01:36 PM
Again, it would be much more beneficial for me to see a video of the procedure done right than for you guys to see me doing it wrong, if that is the case. I've read the directions over and over. If I'm doing it wrong, with all due respect to the members of this board, more reading won't help.
#57 RegUS_PatOff
  • 33,588 posts
Posted 07 April 2013 - 02:00 PM
not many (or maybe none) of us may have that model Fridge / Controller ...
#58 DurhamAppliance
    Sho' Nuff Chozin
  • 5,434 posts
Posted 07 April 2013 - 02:13 PM
And when we are repairing it for a customer, we are usually alone and doing the keypad "dance " while holding a camera is next to impossible.
#59 tpoindexter
tpoindexter
    Senpai
  • PipPipPipPip
  • 656 posts
Posted 07 April 2013 - 07:26 PM
We don't have a video
If we could see how you are doing it, would be easier to correct it, if we saw something being done incorrectly
Sometimes even if you've done it before you still can have problems
Correct. More reading of the SAME instructions, and, more doing it the same way isn't going to get you anywhere.
But, a video of what your currently doing would be helpful in correcting (if there is any) errors.
You may be ask to trying it differently than the way your currently reading it.
I can't tell you have many times I have followed the directions exactly with bad results only to find out later I was doing it just slightly off, or, that the instructions weren't exactly right.
Then again, sometimes the 12th time is the charm!!
Test
#60 Samurai Appliance Repair Man
    Shōgun
  • 30,171 posts
Posted 07 April 2013 - 07:34 PM
Standby, working on that...
