Squeeky GE Profile gas dryer model #DPXH46GF
8 replies to this topic
#1 omgdave
omgdave
    Ikkō-ikki
  • Chief Appliantologist
  • 42 posts
  • Flavorite Brew:Reed's Extra Ginger Brew
Posted 06 January 2013 - 05:39 PM
The title says it- my dryer squeeks as the drum make a revolution. Squeek pause, squeek pause. What are the lube points for this dryer or what could be wearing/worn? we bought this in 05-06 so it has seen good use.
Thank you,
Dave
#2 jumptrout
jumptrout
  • 1,190 posts
  • Flavorite Brew:Coors Light
Posted 06 January 2013 - 06:18 PM
Your rear drum bearing kit # WE25X10001 needs replacing.
#3 KCTBURY
KCTBURY
    Ikkō-ikki
  • 37 posts
  • Flavorite Brew:Coke
Posted 06 January 2013 - 06:29 PM
Sometimes it may be the idler assembly. The drum bearing is the most likely culprit though, as jumptrout stated. You may want to pull the drum out and inspect it. You may just need the drum bearing part listed below.  While you are in there you might want replace the gas coils as preventative maintenance.
http://www.repaircli...1X10218/1168451
Rear drum bearing kit
http://www.repaircli...25X10001/771336
Drum bearing
www.repairclinic.com/PartDetail/Drum-Bearing/WE3X70/276403
#4 omgdave
omgdave
    Ikkō-ikki
  • 42 posts
Posted 06 January 2013 - 08:29 PM
Thank you both. I have done an idler on another dryer and can't imagine a bearing taking much more time. The gas coils are my next question. I didn't see anything called exactly that in the parts list.
#5 RegUS_PatOff
  • 30,670 posts
Posted 06 January 2013 - 09:08 PM
... The gas coils are my next question. I didn't see anything called exactly that in the parts list.
part of the Gas Valve Assembly
http://repairclinic....sp?R=154&N=3449
#6 jumptrout
jumptrout
  • 1,190 posts
Posted 07 January 2013 - 07:01 AM
You could use this kit and get more parts for less money.http://www.repaircli...4461262/1261075
#7 vee8power
vee8power
    Sōhei
  • 125 posts
  • Flavorite Brew:Folgers
Posted 07 January 2013 - 08:06 AM
Looking at the parts breakdown for that model, it looks to me like the correct maintenance kit for your dryer is this one
http://www.repaircli...4457724/1198622
Notice in the picture that the upper felt does not have the three plastic glides. That's because the plastic glide on your dryer is attached to the drum, it is the newer design.
The 5304461262 mentioned above is for the older design, with no plastic glide on the front of the drum.
Another thing worth noting is that this is a GE brand dryer but it is built by Frigidaire. The part #'s for the kits are Frigidaire numbers. You won't find them on the parts breakdown for a GE.
Knowing how parts interchange is one way us professionals can save our customers, and our fellow forum members, some dough.
BTW... gas coils... Whirlpool, GE, an Frigidaire all have part numbers for exactly the same part. Guess which one is Generally  most Expensive
#8 omgdave
omgdave
    Ikkō-ikki
  • 42 posts
Posted 23 April 2013 - 11:09 PM
Ok, a report on the repair process:
This was the correct parts package to order. Installing the parts was one of the easiest repairs I have ever done. Faucet stem washers and seats have taken more time that this! The video attached to the Part # was clear and easy to follow, with one very minor quibble: on my dryers original idler arm is a screw which looks to be used as a safety if the belt ever breaks. It was not mentioned in the instructions, but you would have to be brain-dead and blind to not see it is a required piece to be moved to the new arm.
Thanks again for all the help
Dave
  • 24,677 posts
Posted 26 April 2013 - 10:29 AM
Awesome!  Domo for posting the followup report, Dave!   :thumbsup:  :thanks:
Maintenance Kit for the Newer-Style Frigidaire-built Dryer (also sold under the GE brand)
By Samurai Appliance Repair Man in Samurai Appliance Repair Man's Blog, on 26 April 2013 - 10:34 AM
One of the little secrets in the appliance manufacturing world is that the manufacturers will often build appliances for each other. One example of this is certain models of GE dryers are actually built by Frigidaire but sold under the GE label.
There are two maintenance kits out there for Frigidaire-built dryers:
- part number 5304461262 for the older-...
Read Full Entry →
