Lg lds4821bb not getting dishes clean
11 replies to this topic
#1 zdog
zdog
  • 5 posts
  • Flavorite Brew:Pilsner
Posted 07 January 2013 - 09:59 PM
Hi Folks,
This dishwasher has been doing a crappy job of getting the dishes clean since new 2 years ago. I pulled the unit today so I could do some tile work and found that the drain line was crimped almost flat.  My questions are:
1.  Is this most likely what is causing the dishes not to get clean?  The drain must be allowing some liquid through because there is no standing water when the cycle is over.
2.  Is there a way to repair the crimp so I don't have to buy that $35 part?
3.  Should I give in to the wife and buy a new dishwasher?
Many thanks,
zdog
#2 john63
john63
  • 1,411 posts
Posted 07 January 2013 - 11:14 PM
For this model---a SERIAL NUMBER is needed to narrow possible fault(s).
<<<1.  Is this most likely what is causing the dishes not to get clean?>>>
Yes--a badly crimped DRAIN HOSE can cause poor wash results.
Edited by john63, 07 January 2013 - 11:19 PM.
To eliminate:
Musty odor
L-O-N-G cycle times
Dingy/yellowing whites
Suds error message
Slow spin speeds
Read below:
HE 2X: (1) Tablespoon
HE 3X: (1) Teaspoon
#3 zdog
zdog
  • 5 posts
Posted 07 January 2013 - 11:26 PM
Thanks for the reply.  The S/N is 007KWJU00524.
Is there a way to fix that crimped section of drain hose?
zdog
#4 john63
john63
  • 1,411 posts
Posted 07 January 2013 - 11:52 PM
Built July 2010---a sweet spot during production :)
No issues for this build date other than a *possible* noise complaint (low whistling sound during wash). Caused by a re-designed CHOPPER (also known as Macerator Blade). Can be replaced if desired---simple.
In your case---the dishwasher was improperly installed---resulting in a crimped/damaged DRAIN HOSE (AEM69493803) which **will** leak water at some point in time.
A slow drain will cause less-than-ideal-cleaning results.
Not repairable.
It's a guaranteed leak waiting to happen---install a new DRAIN HOSE.
Verify that the dishwasher Hot Water supply and Drain Hoses are *correctly* routed/installed (consult INSTALLATION MANUAL).
The dishwasher wash performance will be greatly improved.
To eliminate:
Musty odor
L-O-N-G cycle times
Suds error message
Slow spin speeds
Read below:
HE 3X: (1) Teaspoon
#5 zdog
zdog
  • 5 posts
Posted 08 January 2013 - 12:05 AM
I appreciate your advice.
Good luck,
zdog
#6 RegUS_PatOff
  • 30,700 posts
Posted 08 January 2013 - 03:16 AM
Drain Hose AEM69493803
New updated drain hose.
*Black rubber hose goes to top of water inlet housing on side of dishwasher.
May need to order item# 1267810 as well
http://www.repaircli...R=154&N=1557758
Water Inlet 4975DD1001A
Water inlet with water meter and ports at top
http://www.repaircli...R=154&N=1267810
#7 Chat_in_FL
Chat_in_FL
    Senpai
  • PipPipPipPip
  • 911 posts
  • Flavorite Brew:Variety is the spice of life!
Posted 08 January 2013 - 06:23 AM
You can also crimp (block) the black rubber hose off to retro-fit the new drain hose, instead of additonally buying the new water inlet.
Edited by Mrs. Samurai, 12 May 2013 - 08:31 PM.
Mother Teresa
#8 john63
john63
  • 1,411 posts
Posted 08 January 2013 - 10:45 AM
The AEM69493803 DRAIN HOSE is a direct-fit for this dishwasher---the GUIDE ASSY (2nd part pictured) is not needed.
Earlier models (determined by Serial Number) *did* have a different...
1) MAIN BOARD (programmed to partial drain)
2) DRAIN HOSE (does not have an anti-siphon break)
3) GUIDE ASSY (does not have a connector for the anti-siphon hose)
To eliminate:
Musty odor
L-O-N-G cycle times
Suds error message
Slow spin speeds
Read below:
HE 3X: (1) Teaspoon
#9 zdog
zdog
  • 5 posts
Posted 08 January 2013 - 12:45 PM
 Thanks for the info everyone.
Just out of curiousity.....is this an OK dishwasher or did I screw up when I walked into Home Depot and asked for the quietest machine they had?
zdog
#10 john63
john63
  • 1,411 posts
Posted 08 January 2013 - 08:42 PM
<<<is this an OK dishwasher>>>
Yes :)
To eliminate:
Musty odor
L-O-N-G cycle times
Suds error message
Slow spin speeds
Read below:
HE 3X: (1) Teaspoon
#11 zdog
zdog
  • 5 posts
Posted 11 January 2013 - 07:01 PM
OK Folks, time for a little feedback.
I ordered, received and installed a new drain hose.  I ran the machine for the first time after that today.  I told the wife to just load the dishes in and don't worry about it pre-cleaning.  Good News.....everything came out cleaner than ever before.  I can start talking nice to my machine now instead of threating it with replacement.
Thanks again for the help,
zdog
#12 john63
john63
  • 1,411 posts
Posted 11 January 2013 - 09:39 PM
Good job :)
To eliminate:
Musty odor
L-O-N-G cycle times
Suds error message
Slow spin speeds
Read below:
HE 3X: (1) Teaspoon
