wt5001c grinding noise in spin
5 replies to this topic
#1 aasnowskate
aasnowskate
    Ikkō-ikki
  • Chief Appliantologist
  • 27 posts
  • Flavorite Brew:pabst
Posted 08 January 2013 - 04:02 PM
Had customer call about grinding noise in spin cycle.  Also clothes not wrung out enough because tub not spinning fast enough.
LG top load washer.
M# WT5001C
I looked up the tech manual at Appliantology.org (thanks) and it is a direct drive.
Just wondering if anyone had encountered this problem.  And wanted to know if it is a complete tear down to replace the coupling?  What is the best way to go about taking that apart.  It also looked as if a coin or nail could get down under the "puls" plate.  I am guessing it is called that. There was no parts list in the tech manual.
Thanks for any help.
#2 RegUS_PatOff
  • 30,232 posts
Posted 08 January 2013 - 04:29 PM
... wanted to know if it is a complete tear down to replace the coupling?
not like a typical Whirlpool Top Loader w /Coupling ...
#3 aasnowskate
aasnowskate
    Ikkō-ikki
  • 27 posts
Posted 08 January 2013 - 04:46 PM
Have you come across this problem before?  Should I look toward the coupling as the problem?  I am guessing I access this from the back and pull it apart from the bottom up.
#4 kdog
    RoughShod
  • 7,428 posts
Posted 08 January 2013 - 07:20 PM
Similar issue here
  • 24,271 posts
Posted 09 January 2013 - 06:44 PM
Grinding in spin... first stop is the drain pump.  Get into test mode and run the drain pump.  If gravelly-sounding, come git you one ==> http://www.repaircli...EA1004E/2134503
#6 mark mac
mark mac
    Sōhei
  • 190 posts
Posted 10 January 2013 - 10:03 AM
not a bad job u need a 38mm socket to remove  basket nut, regular threads, replace k-170 comes as a whole unit ,once u get basket out.everything drops from underneath should take 1 to 1/2 hrs
