Troubleshoot Maytag Neptune Stack MLG2000AWW Won't finish spin cycle
5 replies to this topic
#1 Viking1
Viking1
  • 2 posts
  • Flavorite Brew:GB Nordeast
Posted 08 January 2013 - 04:26 PM
Washer does not finish spin cycle.  Control dial finishes but clothes are still more wet than normal.  Little water in the bottom of drum (1-2 cups).  What troubleshooting steps should I take to determine problem.
#2 RegUS_PatOff
  • 30,201 posts
Posted 08 January 2013 - 04:48 PM
Is the Drain clogged ?
Is the Pump clogged ?
Is the Pump Impeller damaged ?
http://appliantology...16009127-c1998/
#3 Viking1
Viking1
  • 2 posts
Posted 08 January 2013 - 07:02 PM
It runs a full cycle, fills with water, rinses fine so I suspect draining is not the issue.  We ran a couple of cycles.  This would rule out drain issue wouldn't it?   I will check drain.
#4 nickfixit
nickfixit
  • 1,964 posts
Posted 09 January 2013 - 06:20 AM
Check wax motor and spin enable micro switch, after verifing pump performance.
#5 sh2sh2
sh2sh2
    Sōhei
  • 211 posts
  • Flavorite Brew:yeunling
Posted 09 January 2013 - 05:13 PM
does door lock light come on?
#6 dimitri77565
dimitri77565
    Ikkō-ikki
  • Chief Appliantologist
  • 52 posts
  • Flavorite Brew:Railean Hand Made Rum
Posted 09 January 2013 - 05:51 PM
Unless you sit & watch the whole cycle YOU are doing allot of assuming.  What is the brand? model number? maybe it never drains after wash?
