Viking1
Troubleshoot Maytag Neptune Stack MLG2000AWW Won't finish spin cycle
6 posts in this topic
Washer does not finish spin cycle.  Control dial finishes but clothes are still more wet than normal.  Little water in the bottom of drum (1-2 cups).  What troubleshooting steps should I take to determine problem.
It runs a full cycle, fills with water, rinses fine so I suspect draining is not the issue.  We ran a couple of cycles.  This would rule out drain issue wouldn't it?   I will check drain.
Check wax motor and spin enable micro switch, after verifing pump performance.
does door lock light come on?
Unless you sit & watch the whole cycle YOU are doing allot of assuming.  What is the brand? model number? maybe it never drains after wash?
