Microwave Door Flopping Down, What Parts?
10 replies to this topic
#1 AlexM
AlexM
    Kohai
  • Chief Appliantologist
  • 263 posts
  • Flavorite Brew:Root Beer
Posted 08 January 2013 - 09:36 PM
This Microwave; Kitchenaide Model# KBMC140HSS03 has the door that flops down.  I tried looking up the two springs, left and right because I think they need to be replaced.  I was confused looking at the blowed up diagram, Do i just need the left and right springs? and what would the correct part numbers be, i looked up a couple different part numbers.  Assuming I can get this repaired, will the new springs work as well as the factory ones did?
#2 Strathy
Strathy
    Kohai
  • 392 posts
  • Flavorite Brew:DP.
Posted 08 January 2013 - 09:43 PM
You need both torsion bars.  Usually only one is broken, but I replace both at the same time.
EDIT:  I'm coming up with part number 4451009 for both.  I know the stainless ones are 2 different ones, not sure about the black model though.
Edited by Strathy, 08 January 2013 - 09:45 PM.
Neighbour's Appliance Service
Servicing Southern Manitoba, Canada
#3 RegUS_PatOff
  • 30,700 posts
Posted 08 January 2013 - 10:30 PM
4451009 Black / White / Biscuit models
4452396 Stainless model (stronger tension)
(original SS models may have had one of each)
http://www.repaircli...?R=154&N=589688
http://www.repaircli...?R=154&N=829228
#4 Strathy
Strathy
    Kohai
  • 392 posts
Posted 08 January 2013 - 11:09 PM
Actually the stainless model uses 2 different bars.  4452396 and 4452395 - the diagram is wrong.  Not sure about how it works with the black model though.  Not sure if they are both the same or not.
#5 RegUS_PatOff
  • 30,700 posts
Posted 08 January 2013 - 11:17 PM
could be .. but diagram & parts list is from the Whirlpool website
also, another model:
http://appliantology...oor-flops-down/
#6 Strathy
Strathy
    Kohai
  • 392 posts
Posted 08 January 2013 - 11:40 PM
Neither here nor there - his is a black model and I don't remember how those ones are.  According to my parts records, I changed 42 of the stainless ones last year though ... those ones I knows what I knows.  lol.
Just checked my truck:
4452396 Heavy Spring
4452395 Light Spring
4451009 Medium Spring
My guess is that he has one medium and one light one on his.  I've often replaced the factory installed one light and one heavy with 2 mediums which seems to have about the same tension, but that was always on the stainless units.  Only guessing on the black one.
#7 RegUS_PatOff
  • 30,700 posts
Posted 09 January 2013 - 02:33 AM
... Kitchenaide Model# KBMC140HSS03
My eyesight isn't as good as it once was blink.gif (see RegUS_PatOff )
but from here it looks like his model is stainless steel
#8 Strathy
Strathy
    Kohai
  • 392 posts
Posted 09 January 2013 - 09:11 AM
What??? lol.  Not an eyesight issue on yer part!  Don't know where I got the idea it was black ... lol.  Sorry guys.
#9 AlexM
AlexM
    Kohai
  • 263 posts
Posted 09 January 2013 - 09:52 AM
O.K., now I need some clarification, the unit I was looking at has a stainless steel exterior and the inside of the door is black. Should I order the different springs ending in 95 & 96?
#10 Strathy
Strathy
    Kohai
  • 392 posts
Posted 09 January 2013 - 09:56 AM
Yes - that is a Stainless model - don't know where I came up with black! Sorry for the confusion on that. From my experience, I would replace both the /96 and the /95. However, I have also put in two /09's and had it work pretty well too. You will likely find that only the /96 (heavy one) is broken at the elbow - but I've had better luck changing both than just the broken one.
Edited by Strathy, 09 January 2013 - 02:02 PM.
#11 Strathy
Strathy
    Kohai
  • 392 posts
Posted 09 January 2013 - 06:34 PM
Good luck with that ...
How to Fix a Kitchenaid Microwave Oven with a Door that Flops Down Hard
By Samurai Appliance Repair Man in Samurai Appliance Repair Man's Blog, on 09 January 2013 - 05:12 PM
The deal here is that one of the torsion bars is broken.  Even though it's usually only one that breaks, you want to replace both as a set.  For the stainless steel models, Grand Master Reg  hooks up with the needed parts and diagram: Source: Microwave Door Flopping Down, What Parts?
Read Full Entry →
