Frigidaire front load washer FTF2140ES1 won't spin
Frigidaire front load washer no spin
16 replies to this topic
#1 MKeating42
MKeating42
  • 19 posts
  • Flavorite Brew:OIe Leghumper
Posted 09 January 2013 - 09:37 AM
I'm beginning to truly hate this washer.
I happened to be ten feet away when the washer quit working. The spin cycle had just started. Drain kicked on, drum started spinning, then the washer started "walking" because of an imbalanced, heavy load. Before I could reach it, it just quit. No lights, no beeps, no error codes. Checked to make sure it was still on the stand, then put it in diagnostic mode to spin it out. I had the door lock problem some time ago so I knew how to go about doing that (thanks guys!).
The drain came on but after a few seconds it stopped. The drum never spun. Hoping that it was just a clogged pump/drain, I took it apart, cleaned it out. Didn't find anything. Reassembled and tried the test again. This time I paid a little closer attention, and it seems like the washer shut down when the drum tried to start. It also started flashing error E5E - communication error.
The service manual says E5E is a communication error, and refers to Test 13: "Communication problem. Check the wiring between the control board and the speed control board." (already sounds expensive)
"Wiring bad: correct wiring problem. Wiring good: Replace the control board. If the problem is not corrected, replace the speed control board." (sounding more expensive...)
I see a similar problem with another Frigidaire model in this post.
If the washer doesn't spin in diagnostic mode, that points to the control board instead of the latch, correct? Because diag mode overrides the door lockout?
I guess I'm looking for confirmation that it's the control board before I spring for a new one.
#2 RegUS_PatOff
  • 30,700 posts
Posted 09 January 2013 - 09:51 AM
depending on the severity, the imbalance / walking (which may be a major mechanical problem)
may have caused the Connectors to come loose on the Motor Controller or on the Motor
Will it still Wash / Agitate / Tumble ?
#3 certified tech group 51
  • 2,043 posts
Posted 09 January 2013 - 11:45 AM
Check the speed control board .........There is a wire harness , 5  wires, that I have found after a wild spin, the harness becomes slightly disconnected...............Still in place but, unplugged..........Then check the wire terminal connection on the motor, brown wire........did it get pulled loose??????....the wire harness is zip tied to the floor but not enough movement is allowed..............Check the lock assy, wild spinning  has been known the hit the lock assy.............Switch all the parts but I think it is a pulled wire or connection..................
#4 sh2sh2
sh2sh2
    Sōhei
  • 226 posts
  • Flavorite Brew:yeunling
Posted 09 January 2013 - 05:15 PM
i second the loose wires at motor control, i have seen this problem before and it is the same as u describe, drian pump runs for 2 seconds then nothing, wait a minute and it repeats
#5 MKeating42
MKeating42
  • 19 posts
Posted 09 January 2013 - 06:26 PM
Lock test works. Door also locks when I run the drain/spin test (but no spin).
When I run the fill/tumble test, the washer fills but no agitation whatsoever.
Not sure what the speed control board looks like. I'll dig around here/RepairClinic for an image.
I don't suppose there's an easy way to get to the wiring harness on the motor? It's at the back of the cabinet, and I can't eyeball the harness from the service panel.
Edited by MKeating42, 09 January 2013 - 06:28 PM.
#6 MKeating42
MKeating42
  • 19 posts
Posted 09 January 2013 - 06:31 PM
The Speed Control Board = Motor Control Board?
Repair Clinic link
#7 RegUS_PatOff
  • 30,700 posts
Posted 09 January 2013 - 06:38 PM
yes
http://appliantology...ntload-washers/
  • 24,717 posts
Posted 09 January 2013 - 06:48 PM
Have you checked the drum bearings in accordance with the patented Samurai Technique™?
#9 MKeating42
MKeating42
  • 19 posts
Posted 09 January 2013 - 06:53 PM
Well. I think I've found the problem:
Now, I'm no expert, but I'm pretty sure those wires weren't chewed up like that when I bought the thing. So yes, "loose wires" for an extreme definition of "loose."
The good news: new harness much (MUCH!) less expensive than motor control board.
The bad news: It's backordered at Repair Clinic - out of stock for 3-5 weeks.
Thanks for the help guys.
I had not, but oddly enough a 2" wolf spider decided to amble across my keyboard while I was watching the vid. I told him to skedaddle unless he was going to pay my subscription.
Edited by MKeating42, 09 January 2013 - 06:55 PM.
#10 RegUS_PatOff
  • 30,700 posts
Posted 09 January 2013 - 07:14 PM
this one ?  $59
http://www.repaircli...R=154&N=1156892
#11 MKeating42
MKeating42
  • 19 posts
Posted 09 January 2013 - 08:06 PM
this one ?  $59
When I search by model# RC gives me this one (Item # 1163239).
Wiring-harness-motor-control-134547600-0
But they're both out of stock.
#12 MKeating42
MKeating42
  • 19 posts
Posted 09 January 2013 - 08:15 PM
Would it be prudent to solder the wires back together? Or am I just asking for more trouble?
#13 RegUS_PatOff
  • 30,700 posts
Posted 09 January 2013 - 08:48 PM
that's not the one ...
none of the (3) listed at RepairClinic are the one you need
(wrong wire colors)
You need the one shown on the wiring diagram on the left of the Motor Controller
that connects to the Main Controller
(it has your wire colors)
134543000 is the only one on Frigidaires parts list that isn't shown ...
which is probably the one you need
#14 MKeating42
MKeating42
  • 19 posts
Posted 09 January 2013 - 09:24 PM
(wrong wire colors)
Wow. that's weird. I couldn't see the part of your message with the part number in it. And you're right - I traced the wires back to the main control board:
harness_interface20130109_210231-1a_zps1
#15 RegUS_PatOff
  • 30,700 posts
Posted 09 January 2013 - 09:38 PM
may be easier (and cheaper) to just splice the wires back together ...
(there may still be something wrong with the balancing / walking problem)
#16 MKeating42
MKeating42
  • 19 posts
Posted 09 January 2013 - 11:00 PM
Woohoo! splice the wires back together, tested for continuity, plugged it back in and it works!
Thanks again for all the help.
Edited by MKeating42, 09 January 2013 - 11:01 PM.
#17 Samurai Appliance Repair Man
  • 24,717 posts
Posted 10 January 2013 - 08:35 AM
Awesome!  Great job tracking down the problem and fixing it!   :rocker:
