Danby Silhouette Beverage Fridge - no power to compressor
8 replies to this topic
#1 AlexM
AlexM
    Kohai
  • Chief Appliantologist
  • 263 posts
  • Flavorite Brew:Root Beer
Posted 09 January 2013 - 10:00 AM
This Danby Beverage Fridge Model# DBC2760BLS is not cooling.   Both evaporator fans work well, the compressor and condenser fan not working.  I put a hard start kit on and could only get it to start the compressor with a external 120v power cord, the it seemed to run fine.  Is this as simple as replacing the relay and capacitor?  Also, is this a Samsung? and does anybody have the service manual?  Thanks
#2 certified tech group 51
  • 2,043 posts
Posted 09 January 2013 - 11:18 AM
Is there 120 v. A.C. to the condenser fan and the compressor ???
#3 AlexM
AlexM
    Kohai
  • 263 posts
Posted 09 January 2013 - 01:13 PM
No, some weird voltage coming from the capacitor, but yes to the fan when I had my cheater cord plugged into the start kit, fan ran great then.
#4 RegUS_PatOff
  • 30,698 posts
Posted 09 January 2013 - 01:47 PM
do you have a tech sheet or wiring diagram you could post ?
#5 certified tech group 51
  • 2,043 posts
Posted 09 January 2013 - 03:06 PM
Does this unit have a two zone cooling capacity??? ................. two evap fans..................Is there an electronic board that runs the two zones????.....Hidden in the back,  If I remember........
#6 dimitri77565
dimitri77565
    Yamabushi
  • 61 posts
  • Flavorite Brew:Railean Hand Made Rum
Posted 09 January 2013 - 06:06 PM
Sensei     u right it does have 2 zones. those boards go bad also when 1 zone goes out (restriction etc) the 2nd zone will work for 24 hrs & then shut down ALSO.
#7 AlexM
AlexM
    Kohai
  • 263 posts
Posted 09 January 2013 - 07:42 PM
Yes this does have the two fans, one in each compartment and no I didn't get my hands on a wiring diagram....
#8 AlexM
AlexM
    Kohai
  • 263 posts
Posted 25 January 2013 - 01:37 PM
OK so i installed both control boards and main board P/N DG3-45, and new Start Relay P/N QP2-4.7, and new Overload P/N B99-125.  I plugged the unit back in and all I get is a consistent beeping noise and flashing blue lights on the interior, its a quick beep, like one per second.  I pressed the control buttons in various ways trying to reset the unit, didn't work.  Did I get a bad board? is there something else I'm overlooking?  Oh and the evaporator fans 'jump' but don't turn everytime the beep happens.
#9 Comstock_Services
Comstock_Services
  • 462 posts
Posted 31 January 2013 - 08:45 AM
Sounds to me (JUST A GUESS) that you should put the old boards back in and see if the evaporator fans are still running normal. then I would check the power into the board, and check the power relay on the boar for the compressor, and condenser fan motor. there should be a wiring diagram some where on the unit. Try looking behind the kickplate, under the front of the unit too.
