Viking VDSC4854GGG 48" DUAL FUEL
RH oven no bake no broil
5 replies to this topic
#1 prairiestr
prairiestr
    Sōhei
  • Chief Appliantologist
  • 189 posts
  • Flavorite Brew:Jack
Posted 09 January 2013 - 08:24 PM
I'm gonna need help with this one.
 RH oven no bake or broil. Elements ok. Tough to read wiring diagram. Very small.
L1 present at red wire at selector sw.
L2 appears to be present at wt/bu wire at sel.sw.
In bake position, thermostat set 350, 240v between red(L1) and wh/bu(L2) at selector sw.
Yet, no heat?
Help please.
#2 KurbyMstr
KurbyMstr
    Yamabushi
  • 63 posts
  • Flavorite Brew:Cherry Coke
Posted 09 January 2013 - 10:26 PM
Are you getting any voltage at the elements themselves?  Do you have a model number so we can take a look at the wiring diagram?
#3 prairiestr
prairiestr
    Sōhei
  • 189 posts
Posted 10 January 2013 - 12:10 AM
Model # listed in topic title. VDSC4854GGG
I didn't check voltage @ elements, :stupid:  but I would guess that 0v across and 120v to ground.
#4 KurtiusInterupptus
KurtiusInterupptus
    B.M.F.
  • 1,470 posts
  • Flavorite Brew:Killians Red
Posted 10 January 2013 - 07:54 AM
Check for burnt wire/terminal at big molex plug at right and/or left rear corner.
#5 KurbyMstr
KurbyMstr
    Yamabushi
  • 63 posts
Posted 10 January 2013 - 10:53 AM
My bad on the model number. I'm with Kurtius on checking the wiring.
#6 prairiestr
prairiestr
    Sōhei
  • 189 posts
Posted 10 January 2013 - 02:05 PM
Kurtius & Kurby,
Thanks for the tip, I'll try to check that today. :thanks:
