KSSS42MDX03 Requesting service manual
4 replies to this topic
#1 herfdog
herfdog
    Ikkō-ikki
  • 54 posts
Posted 14 January 2013 - 07:42 PM
First of all I am requesting a service manual for a Kitchen Aide fridge model KSSS42MDX03.
Second, I am having a hard time figuring this one out. The evap fan is not working, there is 120 volts to fan, checking neutral to hot. I replaced the fan it still does not work so I hooked it up to 120 volts from a different power source, it works fine. I even ran a neutral from light using existing hot wire but it still wouldn't work. Any ideas?
#2 KurtiusInterupptus
KurtiusInterupptus
    B.M.F.
  • 1,470 posts
  • Flavorite Brew:Killians Red
Posted 14 January 2013 - 07:47 PM
Sounds like empty voltage...some connection is failing under load. Trace the hot wire back and eliminate sections till you find it. Does the fan go thru the bimetal on this one?
Edited by KurtiusInterupptus, 14 January 2013 - 07:54 PM.
#3 RegUS_PatOff
  • 30,269 posts
Posted 14 January 2013 - 08:24 PM
... The evap fan is not working, there is 120 volts to fan
unless otherwise directed, all voltages should be measured with all devices connected ...
http://www.repaircli...?R=154&N=829022
#4 herfdog
herfdog
    Ikkō-ikki
  • 54 posts
Posted 15 January 2013 - 10:45 AM
The neutral may go through the bimetal but i temporarily bypassed it with the same results. Empty voltage makes sense, I'll put each section under a load to test. Thanks
Yes, there is no voltage under load. So you think it's the control? Where is it located? Could I get that service manual? Thanks
#5 RegUS_PatOff
  • 30,269 posts
Posted 15 January 2013 - 11:08 AM
yes
I don't have a service manual for that 1996 model
The 2001 model (service manual) uses a different Controller
Refrigerator Main Control Board # 3
