wp cabrio wtw6600sw
7 replies to this topic
#1 eveready service
eveready service
    Ikkō-ikki
  • Chief Appliantologist
  • 45 posts
  • Flavorite Brew:miller high life
Posted 14 January 2013 - 08:19 PM
Hi
The cust. called me and said washer is dead and gave him an error code of f50 &f51. Do you guys have a list of error codes on these washers? I'm not familiar with these machines , But I guess I'm gonna have to jump in sooner or later.
#2 KurtiusInterupptus
KurtiusInterupptus
    B.M.F.
  • 1,507 posts
  • Flavorite Brew:Killians Red
Posted 14 January 2013 - 08:22 PM
Both are RPS sensor errors...
You'll prolly need to update the sensor, harness and control.
Ouch
Sensor and harness ==> http://www.repaircli...0183157/1394136
Rotor-Position-Sensor-W10183157-01069962
Control ==> http://www.repaircli...0189966/1469076
Main-Control-Board-W10189966-00704579.jp
Edited by Samurai Appliance Repair Man, 15 January 2013 - 08:17 AM.
Added part links to sensor, harness and control.
#3 eveready service
eveready service
    Ikkō-ikki
  • 45 posts
Posted 14 January 2013 - 08:43 PM
#4 Scottthewolf
Scottthewolf
    Senpai
  • 1,933 posts
Posted 14 January 2013 - 11:17 PM
Also check for clothes or foreign objects stuck in between the inner wash basket and the outer tub and for a loose bolt on the rotor at the bottom of the machine.
RPS= Rotor Position Sensor
Scott Wolf
#5 KurtiusInterupptus
KurtiusInterupptus
    B.M.F.
  • 1,507 posts
Posted 15 January 2013 - 08:19 AM
thanks boss!
  • 24,721 posts
Posted 15 January 2013 - 08:22 AM
Just tag teamin' it wit ya!   :thumbsup:
#7 KurtiusInterupptus
KurtiusInterupptus
    B.M.F.
  • 1,507 posts
Posted 15 January 2013 - 08:37 AM
definitely check for items stuck between tub/basket and loose rotor bolt ,like Scott sez...ALOT cheaper than the other things!
#8 Skiter29
Skiter29
    Kohai
  • 316 posts
Posted 15 January 2013 - 07:37 PM
lift up on the tub then try it fixed many like that also if it does come down to where you need the control board and wiring harness ive called the whirlpool tech line and they have transfered me to the  partner team and becasue of those errors they took care parts and labor but it will depend how old it is but it wouldnt hurt to call
