STUPID dishwasher installs
15 replies to this topic
#1 Scottthewolf
Scottthewolf
    Senpai
  • 1,933 posts
Posted 16 January 2013 - 10:16 PM
Ok, I have had it with dishwashers installed so far away from the sink and through solid cabinets that it's impossible to get the drain and fill hoses out and back in the tiny holes in the kitchen cabinets.  It's as if the contractor built the kitchen cabinets around the dishwasher.
I had one today where it was impossible to pass the drain hose through the tiny holes in the solid cabinets. I've tried taping hard sticks to the drain hose and even zip tying hard sticks to the drain hose and still the hose won't stay stiff enough to pass through the holes.
ANY ideas aside from telling the customer to cut out one side wall of the kitchen cabinets?
Can somebody tell these knuckleheads that dishwashers NEED to be installed as close to the kitchen sink as possible  so you don't need to join 2 drain hoses together and the dishwasher needs to be installed SQUARELY with the cabinets and not at an angle or corner?
Scott Wolf
#2 RegUS_PatOff
  • 30,708 posts
Posted 17 January 2013 - 01:10 AM
I'm not sure if I understand ...
How about inserting a length of straight or curved copper tubing (of appropriate diameter to just barely fit) to the inside of the drain hose
to fish it through the small Cabinet hole ?
#3 Scottthewolf
Scottthewolf
    Senpai
  • 1,933 posts
Posted 17 January 2013 - 11:14 AM
tried that, it didn't work
Scott Wolf
#4 certified tech group 51
  • 2,045 posts
Posted 17 January 2013 - 11:24 AM
I carry a spool of para-cord....................When I disconnect any lines , I attach a length of the cord to the  1) drain line , 1) supply line and 1) to the power cord if one is used..........So when the unit is pulled it will pull a length of 'retrieval line'  attached to the lines behind it...............A lot of manufactured homes around here , angled kitchens where the lines are stretched to max plus thru two walls....................... For small holes that need to be enlarged, I carry a drywall saw, I think it is called a 'Fat Max'  by Stanly ....nice sharp teeth.......Just tell the customer up front and make the cut look good.........( who is going to see it any way, hidden behind all the bottles of chemicals and junk ) ..........
#5 kdog
    RoughShod
  • 7,433 posts
Posted 17 January 2013 - 10:07 PM
And after a few years when those chemical fumes work on the plastic hosejoint now buried in behind the cabinets and it springs a leak (inside the cabinetry) .......
#6 Scottthewolf
Scottthewolf
    Senpai
  • 1,933 posts
Posted 17 January 2013 - 10:24 PM
Also a favorite nesting place for mice.
Scott Wolf
#7 J5
J5
    Kohai
  • 335 posts
Posted 18 January 2013 - 01:49 AM
dunno what you are talking about
i carry a 2 inch hole saw , there is no discussions with the customer
they call , i install , holes where required
must be an american thing ??
i have only had a couple of installs i have declined till they did the hole and these were because the power or water was directly where
the hole needed to be drilled through and i wasnt taking the risk to drill through power or water
Edited by J5, 18 January 2013 - 01:51 AM.
#8 john63
john63
  • 1,411 posts
Posted 18 January 2013 - 02:43 AM
<<<i carry a 2 inch hole saw , there is no discussions with the customer
they call , i install , holes where required>>>
Touche :)
Reminds of :
I came,I conquered and I left.
Edited by john63, 18 January 2013 - 02:45 AM.
To eliminate:
Musty odor
L-O-N-G cycle times
Dingy/yellowing whites
Suds error message
Slow spin speeds
Read below:
HE 2X: (1) Tablespoon
HE 3X: (1) Teaspoon
#9 certified tech group 51
  • 2,045 posts
Posted 18 January 2013 - 11:22 AM
Some customers do not like extra hole added to the cabinets........looks like Swiss cheese..............I will just enlarge the existing hole......................In the tool box , I also carry a hole saws 1 1/2 " up to 4 1/4".................Never know when a dryer vent needs to be installed.......
#10 john63
john63
  • 1,411 posts
Posted 18 January 2013 - 11:57 AM
<<<I will just enlarge the existing hole>>>
In most cases---when installing a "tall tub" dishwasher---the original hole(s) cannot be used.
Two new holes are needed at the base of the cabinet (very low).
I save those reversible metal sheets used on old dishwashers (each side has a different color---white--black--bisque).
Cut a small section of the sheet metal---use silicone adhesive and 4 small screws to cover the original cabinet holes.
To eliminate:
Musty odor
L-O-N-G cycle times
Suds error message
Slow spin speeds
Read below:
HE 3X: (1) Teaspoon
#11 grey shrek
grey shrek
    Kohai
  • 404 posts
Posted 03 April 2013 - 02:47 PM
Just as much fun as  : hooked to cold water line      25 ft. of cheap drain hose that collapses in the middle                 10 ft. of 1/4 inch soft copper feeding water to unit             new tile floor installed in front of unit                        new "soft" lino in kitchen
#12 Chat_in_FL
Chat_in_FL
    Senpai
  • PipPipPipPip
  • 911 posts
  • Flavorite Brew:Variety is the spice of life!
Posted 05 April 2013 - 08:25 PM
did you mean Primer cord?
http://encyclopedia2...com/Primer cord
Mother Teresa
#13 Scottthewolf
Scottthewolf
    Senpai
  • 1,933 posts
Posted 08 April 2013 - 07:16 PM
Got another one for ya,
They drilled the hole thru the floor all the way on the left side of the dishwasher for the water line and because it's too close to the frame of the dishwasher they took the water valve off its mounting bracket laid the water valve on the floor and wrapped the water line around on the outside of the frame of the dishwasher and it got in the way of the door spring and the hinge, causing the door to come off it's hinge totally.
Scott Wolf
#14 RegUS_PatOff
  • 30,708 posts
Posted 08 April 2013 - 07:58 PM
pictures ?
camera phone ?
#15 Scottthewolf
Scottthewolf
    Senpai
  • 1,933 posts
Posted 08 April 2013 - 08:04 PM
pictures ?
camera phone ?
No pictures, I wanted to get the hell out of there as fast as I could because there was mice feeces everywhere. I flagged it for us never to back there again.
Scott Wolf
#16 RegUS_PatOff
  • 30,708 posts
Posted 08 April 2013 - 08:06 PM
more reasons for camera phone ..
