Maytag Dishwasher
3 replies to this topic
#1 ApplianceDoctor
ApplianceDoctor
    Ikkō-ikki
  • Chief Appliantologist
  • 30 posts
Posted 17 January 2013 - 11:59 AM
I have a customer has a Maytag Dishwasher Model # MDBTT59AWQ. Customer says on normal cycle it will run for 10 minutes and shuts off and will not start back. On longer cycle maybe runs for 1 hour and will not start back. I have checked unit twice and cannot catch it in the act of malfunctioning as she describes. Has anyone run in to this problem before.
#2 RegUS_PatOff
  • 30,670 posts
Posted 17 January 2013 - 12:36 PM
loose Door Latch ?
What does she have to do to get it running again ?
  • 24,677 posts
Posted 17 January 2013 - 03:00 PM
Need to see if the motor is still getting voltage when it stops running.  If so, then you need to replace the circulation motor==> http://www.repaircli...mber=MDBTT59AWQ
Circulation-Pump-Motor-6-919922-00677065
#4 Scottthewolf
Scottthewolf
    Senpai
  • 1,933 posts
Posted 17 January 2013 - 10:11 PM
Also check to make sure nobody is inadvertanently turning off a wall switch that controls the dishwasher.
Scott Wolf
