Maytag MSD2959 water lines and more water lines, Help!
3 replies to this topic
#1 vincef
vincef
  • Appliantologist
  • 17 posts
Posted 17 January 2013 - 05:48 PM
I'm working on an MSD2959*** the unit has 2 water solenoid valves, that parts easy.
Someone tried to repair the lines but put them in the wrong places across the 2 valves.
The outlet line on the top valve is hooked up to the water source at the wall and the inlet to the top
valve goes up top to the filter.
The lower valve hase nothing hooked up to the inlet but leaks at the inlet when energized.
The service manual does not show the routing for the water lines, I downloaded it.
Sad part is I just worked on one 3 weeks ago and cant remember the routing.
Any help would be greatly appreciated.
Vince
#2 DurhamAppliance
    Sho' Nuff Chozin
  • 1,750 posts
Posted 17 January 2013 - 08:17 PM
First step is to always provide a Complete model number... Accuracy is always important as well as i think the second 9 should be a 7. Since you also did not provide valve part numbers, I had to spend time guessing your complete model number to pull up a diagram in order to find the valve part numbers. Your assumption that all fridges in that model series use the same valve may be true, but one day you will regret making such an assumption. I just had dinner, so I was in a good enough mood to go through the trouble. In essence, help us help you.
That aside and using model no. MSD2957GEB, the water line from the faucet should be connected to the inlet on the smaller of the two valves. The outlet from that valve goes to the filter. The filter out line goes to the inlet of the larger valve. Water then leaves that valve to ice maker(smaller line) and water dispenser(larger line)
Edited by DurhamAppliance, 17 January 2013 - 08:29 PM.
#3 kdog
    RoughShod
  • 7,428 posts
Posted 17 January 2013 - 09:52 PM
perhaps the "Y" has been cut out of the original tubing ?
http://www.repaircli...61004391/666239
http://www.repaircli...12001892/936009
Perhaps you have the remaining digits of model number ?
#4 vincef
vincef
  • Appliantologist
  • 17 posts
Posted 31 January 2013 - 01:17 PM
Sorry guys, its a MSD2957AEB. Durham was right, it was a 7 and also right in that
one should not assume when it comes to this stuff. I am experienced enough to know better.
The "Y" is still there. I think that the Y goes to the lower valve (looking in from the back) and the top valve takes
the IM and the dispenser.
