Viking VDSC4854GGG 48" DUAL FUEL
Parts source
9 replies to this topic
#1 prairiestr
prairiestr
    Sōhei
  • Chief Appliantologist
  • 197 posts
  • Flavorite Brew:Jack
Posted 17 January 2013 - 06:30 PM
Looking for a parts source for viking.
I need relay, "relay1" for right oven, located right front under oven door.
#2 Scottthewolf
Scottthewolf
    Senpai
  • 1,933 posts
Posted 17 January 2013 - 10:09 PM
http://www.allvikingparts.com/
Scott Wolf
  • 24,698 posts
Posted 18 January 2013 - 11:57 AM
Do you mean you need the control board for the RH oven?  ==> http://bit.ly/VaWO1t
Or are you trying to replace just a relay on the control board?
#4 prairiestr
prairiestr
    Sōhei
  • 197 posts
Posted 18 January 2013 - 01:02 PM
Samurai,
The relay I need is not part of a control board, it is a dpst located under rh oven door. (relay 1 on wiring diagram)
There is a similar relay (relay 4) located under lh oven door.
Scott, thanks for the link.
#5 RegUS_PatOff
  • 30,689 posts
Posted 18 January 2013 - 01:37 PM
do you have a part number ?
OR post a picture of the Relay ?
OR post wiring diagram ...
#6 Budget Appliance Repair
  • 4,031 posts
Posted 19 January 2013 - 08:12 AM
Here's a Google Document file with some repair info and also list the relays and part#'s, covers VDSC dual fuel ranges and the VESO/VEDO single/double electric wall ovens.
See page 16 and 17 for the relay info.
https://docs.google....dit?pli=1&hl=en
Has lots of good info but not what I need on removing the door hinges in the VDSC ranges, includes wiring diagrams.
Edited by Budget Appliance Repair, 19 January 2013 - 08:17 AM.
William Burk (Willie)
Eureka, CA 95501
#7 RegUS_PatOff
  • 30,689 posts
Posted 19 January 2013 - 09:28 AM
you do the math :whistling:
eBay # 200651270509 $ 54
#8 prairiestr
prairiestr
    Sōhei
  • 197 posts
Posted 19 January 2013 - 02:45 PM
Budget and Reg,
Thank you sooooo much for the info and your time.
Reg, stupid question here, i can only see 4 terminals on the Viking replacement and can't really tell on the Omron relay (although the diagram shows 6) can I assume there are 6 as on the original?
Also, is 12vdc correct?
Edited by prairiestr, 19 January 2013 - 03:44 PM.
#9 RegUS_PatOff
  • 30,689 posts
Posted 19 January 2013 - 04:33 PM
... can I assume there are 6 as on the original?
yes, 6 Terminals
(as shown in the eBay listing)
OOOooohhh.. :whistling:
should be 100v -120v AC
previous post edited
#10 prairiestr
prairiestr
    Sōhei
  • 197 posts
Posted 19 January 2013 - 06:14 PM
 Reg.
Thank you, Thank you.
Perfect. :imnotworthy:
